bogging issue
Old Oct 12, 2005 | 10:52 AM
PURPLETERROR aka BIGMATT's Avatar
Default bogging issue b16a into 99cx
I just finished installing a obd1 b16a in a 99cx, running a jdm p30 and jumper harness obd2b-obd1. All wiring is correct, did the iacv fix and swapped all sensor plugs. Customer is telling me that the car is bogging at times, sometimes it pulls hard other times is slower than the other stock motor. Tps is fine, .5closed 4.5 wide open, the only thing i can think of is the map sensor, or the fact that the motor was filthy inside and had crappy compression numbers.
Modified by PURPLETERROR aka BIGMATT at 5:25 PM 10/13/2005
Old Oct 13, 2005 | 08:25 AM
Default Re: bogging issue b16a into 99cx (PURPLETERROR aka BIGMATT)
bump
95b16rr
Oct 10, 2008 05:11 PM
remco
Oct 4, 2008 12:25 AM
Hatchman98
Nov 28, 2006 04:43 PM
amber_eg6
Dec 17, 2004 05:29 AM
