Idling issues....Can timing contribute?
Old Oct 12, 2005 | 10:23 AM
bassysingh's Avatar
Default Idling issues....Can timing contribute?
d16 with bs intake and full exhaust. Used to idle at about 300-500 rpms. Changed cap & rotor (beck & Arnley), Plugs (NGK Iridium), Wires (beck & arnley). Had installed the engine about a week before and it was idling fine. Noticed the distributor bolts were loose, tightened them and may have advanced or reterded the timing......would this play a factor in the new idle speed which is at 1500rpm?
Old Oct 12, 2005 | 10:35 AM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Idling issues....Can timing contribute? (bassysingh)
It could, get a timing light and make sure your IG timing is on. Then go from there.
Old Oct 12, 2005 | 10:47 AM
siregcivic's Avatar
you can only advance/retard your ignition timing on the distributor by 3 degrees each way from tdc so if your at 16tdc it will only go to 19 or 13... advancing the timing 3 degrees will only raise your idle by a couple hundred then the computer will fix it on its own and bring it back down... 1500 rpm is not from the distributor.
check for a loose vacume line or bad fast idle valve
Old Oct 17, 2005 | 07:18 AM
bassysingh's Avatar
Default Re: (siregcivic)
will do thank you
Old Oct 17, 2005 | 10:02 AM
vtakvtrak's Avatar
Default Re: (bassysingh)
bad idle is usually vaccum leaks, IACV or FITV... mine ocassionally does it, at a stop it will go from 1000 to 1400 and back down and back up... its really hard to diagnose though.
gooblinn258
Dec 12, 2013 06:21 PM
trevek10
May 16, 2011 03:07 PM
hannslebo
Jul 26, 2009 02:35 PM
es_squared
Nov 16, 2008 01:49 PM
keebler65
Oct 2, 2003 09:14 PM
