Clutch Problem (Won't engage)
Old Oct 11, 2005 | 03:37 PM
hybrid0006's Avatar
Default Clutch Problem (Won't engage)
Okay, heres some background: My stock b16 basically got all screwed up from being turbo'd. I rebuilt the block and just got it all back in. Started the engine up and everything seemed to be running pretty good. Now here is where the problem comes in. I can put it in gear and all, go through 1st-5th gears and reverse gear, but if I let off the clutch pedal while its in gear it doesn't move. Basically the car won't move when in gear. So I am trying to trouble shoot here. I need all possible problems/solutions.
Old Oct 11, 2005 | 03:45 PM
rainforest's Avatar
Default Re: Clutch Problem (hybrid0006)
did you use take the clutch off? if so did you use a alignment tool. also any noises. fill us in alittle more
Old Oct 11, 2005 | 03:56 PM
hybrid0006's Avatar
No noises. Yes replaced clutch. I have an Exedy clutch in there.
Old Oct 12, 2005 | 03:22 AM
hybrid0006's Avatar
AH HAH. We fixed it. But there is a new problem.
Old Oct 12, 2005 | 04:50 AM
jlangman's Avatar
im having the same problem but im getting a whining noise when i try to let out the clutch. I can move through all the gears but i cant engage. I think i ran the tranny without any oil in it. Could someone please help? also could it be from over filling the tranny (or soaking the clutch? thanks for the help
Old Oct 12, 2005 | 02:15 PM
hybrid0006's Avatar
Default Re: (jlangman)
Sounds like that might be your throw out baring.
Old Apr 2, 2006 | 05:25 AM
BoOsTiN Dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid0006 &raquo;</TD></TR><TR><TD CLASS="quote">Okay, heres some background: My stock b16 basically got all screwed up from being turbo'd. I rebuilt the block and just got it all back in. Started the engine up and everything seemed to be running pretty good. Now here is where the problem comes in. I can put it in gear and all, go through 1st-5th gears and reverse gear, but if I let off the clutch pedal while its in gear it doesn't move. Basically the car won't move when in gear. So I am trying to trouble shoot here. I need all possible problems/solutions.</TD></TR></TABLE>
What was the problem with it? Im having the same problem right now and im hoping maybe its because i only have 1 1/2 quarts of oil in the tranny.
Old Apr 2, 2006 | 03:54 PM
Default Re: Clutch Problem (sfwd dc2)
anyone know?
Old Apr 2, 2006 | 06:07 PM
smokey2.0's Avatar
AH HAH. We fixed it. But there is a new problem. </TD></TR></TABLE>you should post what you did to fix it, and what other problems you encountered!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sfwd dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
What was the problem with it? Im having the same problem right now and im hoping maybe its because i only have 1 1/2 quarts of oil in the tranny.</TD></TR></TABLE> i don't think the oil has anything to do with it, you're only 1/2 qt low!
Old Apr 2, 2006 | 06:10 PM
Default Re: Clutch Problem (smokey2.0)
yeah i know... i filled up the oil and it still does the same. still not sure what happened. the clutch fork moves... hope i dont have to take the tranny off again!
nevermind... i found out why. My driver side axle wasn't fully in completely. I was in such a rush and so tired last night that i didn't double check everything
Modified by BoOsTiN Dc2 at 3:11 AM 4/3/2006
alexsneesby
Aug 18, 2010 12:11 PM
H.
Oct 10, 2004 07:05 PM
92-EG6
Aug 25, 2003 10:02 PM
erikgsr
Apr 6, 2003 12:03 PM
TuRbEeZy
Apr 4, 2003 10:14 AM
