SRS flashes when jumping for CEL codes? P28
Old Oct 11, 2005 | 01:03 AM
EnzoSpeed's Avatar
Default SRS flashes when jumping for CEL codes? P28
When I run my car off of my P28 in "P28" mode, it runs fine. But when I flip the switch to "Uberdata" mode, I get a CEL.
When I try the service connection jumper trick, the CEL comes on solid instead of flashing. Instead, while the solid CEL is present, the SRS light flashes me a code 21? What's with that?
Anyone know what makes the SRS flash? Do I actually have an engine code, or is the CEL just indicating the SRS problem?
Old Oct 11, 2005 | 06:31 AM
drdisco69's Avatar
Default Re: SRS flashes when jumping for CEL codes? P28 (EnzoSpeed)
The SCS connector shorts all the control units in the car to ground, so they all flash any trouble codes they have. So you have a code 21 in your SRS system, and possibly a bad chip, with the solid check engine light.
Old Oct 11, 2005 | 07:02 AM
JimBlake's Avatar
Default Re: SRS flashes when jumping for CEL codes? P28 (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">... and possibly a bad chip, with the solid check engine light.</TD></TR></TABLE>The CEL is SUPPOSED to go on solid when you jumper the SCS connector. Code zero (bad ECU) is when you have a CEL while driving, but the CEL doesn't light up with the jumper.
Old Oct 11, 2005 | 07:35 AM
EnzoSpeed's Avatar
Default Re: SRS flashes when jumping for CEL codes? P28 (JimBlake)
So what does the code mean?
I removed the passenger airbag a while ago which resulted in a constant SRS light while driving. I just installed a new motor and now instead of a constant SRS light, I get the constant CEL.
Old Oct 11, 2005 | 01:04 PM
EnzoSpeed's Avatar
Oh geez, do a search for "SRS flashes". Seems like no one has ever figured this out.
Old Oct 11, 2005 | 03:19 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Oh geez, do a search for "SRS flashes". Seems like no one has ever figured this out. </TD></TR></TABLE>
Waaa, you dont even tell us what year and model it is. Does the srs light stay on when driving?
Old Oct 11, 2005 | 03:52 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Code zero (bad ECU) is when you have a CEL while driving, but the CEL doesn't light up with the jumper.</TD></TR></TABLE>
Thanks for clearing that up then. You'll have to excuse me, none of the ecus I've done have ever gone bad, so I don't have much experience with that.
Old Oct 11, 2005 | 06:32 PM
EnzoSpeed's Avatar
Default Re: SRS flashes when jumping for CEL codes? P28 (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Waaa, you dont even tell us what year and model it is. Does the srs light stay on when driving?</TD></TR></TABLE>
The SRS has alwyas stayed on because I ripped out the passenger airbag.
Old Oct 12, 2005 | 03:47 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">... none of the ecus I've done have ever gone bad, so I don't have much experience with that. </TD></TR></TABLE>Me neither. First time I saw someone on a forum claiming that was a bad ECU, I thought about how that CEL stays on when I jumper the SCS to set spark timing. So I looked it up in my Helm book.
Old Oct 18, 2005 | 11:21 PM
EnzoSpeed's Avatar
For the record, it WAS two separate problems.
Solution:
-Uncheck VTP in uberdata - got rid of solid CEL
-Wire 2ohm resistor across passenger airbag socket
-Reset SRS code manually - got rid of SRS light
shermanyang
Jun 16, 2014 08:22 AM
Cincinnati4g
Jun 7, 2014 01:25 PM
RiipTiide67
Engine Management and Tuning
Jan 16, 2012 06:57 AM
BUILT4BOOST
Apr 2, 2010 02:35 PM
UNKNOWN_MEMBER
Jun 9, 2005 08:09 AM
