How do I tell what year my motor is?
Old Oct 10, 2005 | 08:46 PM
Scotty Dosent Know's Avatar
Default How do I tell what year my motor is?
I need to find out what year my motor is so I can order a obd2-1 conversion harness.
The car is a 93 SI with suposedly a 00 or 01 LS and a 00 GSR tranny. The werid thing about my car is that it is currently running obd2. I need to figure out which jumper harness I need to convert to obd1, weither I need the one for 96-99 or 00-01. I dont want to get one for a 2000 and find out its actually a 99
Old Oct 10, 2005 | 09:06 PM
Kendall's Avatar
What ECU is in the car right now. Without a complete car harness swap the car will still be running on an OBD-1 ECU as there are no plugs to facilitate an OBD-2 ECU.
It is an aftermarket ECU. My friend Jeff took a look at it and said that he thought the ECU was OBD2 also.....maybe I should go look at that too.....
Ok searched somore and went out and pulled my heat sheild and found a stamp that said 9/8 so does this mean that the motor is a 99?
Modified by ECKO1980 at 10:21 PM 10/10/2005
Old Oct 10, 2005 | 09:21 PM
u2civic1's Avatar
Default Re: (ECKO1980)
9/8 would mean 98
there should be a stamp on the head of the motor
Old Oct 10, 2005 | 09:26 PM
Default Re: (u2civic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u2civic1 &raquo;</TD></TR><TR><TD CLASS="quote">9/8 would mean 98
there should be a stamp on the head of the motor</TD></TR></TABLE>
Almost all the threads I have read say that there head says lets say 96 but there car and motor are actually 97s......not that it matters because that still puts my motor in the 96-99 category.
Here is the ECU that my car is currently running, I just pulled it out and took thes a sec ago. says P75?
and the brand....I know nothing about this ECU
Old Oct 10, 2005 | 09:33 PM
Luserkid's Avatar
P75 is a LS ecu. But really theres no way to tell the ecu without looking at the plugs. Show us that and we could tell you what ecu your running.
The thing about the head is the stamp is what the motor is then it was put in a newer car. Like 93 into 94, 96 into 97. atleast thats what i think it is.
Old Oct 10, 2005 | 09:44 PM
Here are pictures of the plugs that go into the ECU hope this helps
Old Oct 10, 2005 | 09:57 PM
Luserkid's Avatar
Those are obd1 plugs, but i ment on the ecu itself to see what ecu is.
Old Oct 10, 2005 | 10:05 PM
dantastic's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Those are obd1 plugs, but i ment on the ecu itself to see what ecu is. </TD></TR></TABLE>
if theres nothing between those plugs and the ecu, you're running an obd1 ecu. the head year stamp is usually a year behind the car's model year. most likely, you have a 99 LS motor.
Old Oct 10, 2005 | 10:11 PM
I dunno those plugs go directly into the ECU so I guess that would make my ECU obd1? I dont see any conversion harness any where.....maybe my friend was mistaken or the stock harness was spliced some where? im confused now lol My friend Jeff that told me that would be Jeff owner of homemadeturbo.com who is a mechanic and honda finatic....
Old Oct 10, 2005 | 10:22 PM
MenaceL.A.671's Avatar
yessssssssss its obd1!!!!
Old Oct 10, 2005 | 10:31 PM
vancoland's Avatar
nice socks
Old Oct 10, 2005 | 10:37 PM
Default Re: (vancoland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vancoland &raquo;</TD></TR><TR><TD CLASS="quote">nice socks</TD></TR></TABLE>
Champion's Biotch!! lol
Well what ever was done to the car apparently its running OBD1 so I shouldnt have a problem running a chipped OBD1 ECU. Would I be able to chip this Jet ECU for my turbo LS project or is it pretty much rendered usless as far as that goes?
Old Oct 11, 2005 | 08:46 AM
Luserkid's Avatar
If you open it up and show me the insides i could tell you if you could get it chipped or not.
I Think its already chipped though since its a company ecu type thing. If it is you might be able to just run a new bin.
japdunce
Feb 22, 2013 11:33 AM
1994dc2
May 27, 2009 05:51 PM
mojackson2390
13
Aug 20, 2008 03:16 PM
JDM CTR EK
Jul 21, 2003 08:57 PM
4drb18ek
Mar 1, 2003 07:42 AM
