Honda S2000 Honda S2000
Just making sure! springs install
Old Oct 10, 2005 | 11:47 AM
S2000Forsale's Avatar
Default Just making sure! springs install
ok, i'm going to install my springs tomorrow ( using stock struts), do i need a stock struts compressor?
I was reading the s2ki.com install guide, but they never mention that tool.
Thank you
Old Oct 10, 2005 | 12:29 PM
papa5murf's Avatar
Default Re: Just making sure! springs install (typeRkill)
it's helpfull but you don't need it
Old Oct 10, 2005 | 12:34 PM
Infinity_Racer's Avatar
Default Re: Just making sure! springs install (03s2kblue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">it's helpfull but you don't need it</TD></TR></TABLE>
EXTREMELY helpful...unless you have someone there to help you...if you have the spring compressor you can install it yourself...i did my springs at like 3 in the morning and it took about an hour and a half by myself...it helps A LOT
Old Oct 10, 2005 | 03:21 PM
WowOzYouRock's Avatar
Default Re: Just making sure! springs install (Infinity_Racer)
you dont need the spring compressor ... thats the easy part, remove/install the spring ... the hard part is to remove/install the suspension assembly to the chassis ... specially the rear part cuz ders not much room to work on , but you can manage it if you know whachu doin
Old Oct 10, 2005 | 03:47 PM
Default Re: Just making sure! springs install (Y2K_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">you dont need the spring compressor ... thats the easy part, remove/install the spring ... the hard part is to remove/install the suspension assembly to the chassis ... specially the rear part cuz ders not much room to work on , but you can manage it if you know whachu doin </TD></TR></TABLE>
really?! i thought that part was easy...a lot easier than what everyone on s2ki made it out to be...oh well
good luck wit your install
Old Oct 11, 2005 | 03:58 AM
thanks for the replys .... today is the big day, just got home and the UPS package was there ....
cheking with Autozone, to see if the have the spring compressor.
Old Oct 11, 2005 | 09:53 AM
Mr. Projekt's Avatar
* B A N N E D *
Lets see if I can explain this right.
When you re-assemble the suspension on your car, use the jack to hold the suspension arms up at the level of the lower shock mount. It helps when you're working by yourself. You bolt in the top mount loosely, then jack the LCA up to the level of the lower mount, thread that long *** bolt, tighten, and done.
Old Oct 11, 2005 | 12:53 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: Just making sure! springs install (Sideways2000)
Two people and a spring comp. will make the job 1000x easier. I wouldn't want to do it by myself, seems a little dangerous if the car is on jacks and you are dealing with a lot of potential energy. Safety first...
Old Oct 11, 2005 | 12:55 PM
* B A N N E D *
Default Re: Just making sure! springs install (NAallTheWAY)
The car is on jackSTANDS, you are using the jack to hold the suspension arm up so you can align the bottom mounting hole.
You're right its easier with two people, but sometimes you don't have that 2nd hand and have to get creative.
Old Oct 11, 2005 | 12:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY &raquo;</TD></TR><TR><TD CLASS="quote">Two people and a spring comp. will make the job 1000x easier. I wouldn't want to do it by myself, seems a little dangerous if the car is on jacks and you are dealing with a lot of potential energy. Safety first...</TD></TR></TABLE>
no skills
Old Oct 11, 2005 | 01:02 PM
* B A N N E D *
of course its dangerous. so is sniffing brake fluid when you bleed it, or rolling a joint down the freeway with the top off, but people do it.
If he's willing to do it himself, more power to him. If he does it without understanding the risks involved, then less power. =P Either ways, he's just looking for pointers.
Old Oct 14, 2005 | 04:06 AM
nsxnext's Avatar
Just don't drop the nut on the rear driver's side. Took me 1 hour to get that **** out from the small area plus that damn fuel line in the way.
Old Oct 14, 2005 | 12:56 PM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default Re: (nsxnext)
autozone rent a free compressor
integraboi2626
Jun 27, 2006 04:39 PM
ityab0y
Suspension & Brakes
12
Jan 6, 2005 09:37 AM
vinuneuro
Mar 4, 2004 04:20 AM
NONKonformyst
May 15, 2002 08:26 PM
Isaac
Sep 25, 2001 02:58 PM
