Need HELP! Shift linkage issue.
Old Oct 10, 2005 | 11:36 AM
loclowd's Avatar
Default Need HELP! Shift linkage issue.
My **** keeps rattling, I don't know wtf it is. It only does it at around 2-3k rpm...here is what happens:
Rev it, hold the RPM in the right spot to hear the rattling. I move my shifter up and down, and the rattling stops and starts. I know it's in my shift linkage/maybe shift lever.
I looked at it, and there is some play on the reverse lever on the tranny end of it. Same thing with the regular shift linkage.
I don't know where the hell this rattling is coming from, it's annoying the expletive out of me, it's not a heat shield or anything.
Thanks in advance for any input
Lowd
Old Oct 10, 2005 | 12:50 PM
philosofy1's Avatar
Default Re: Need HELP! Shift linkage issue. (loclowd)
are you sure the shifter is not rattling up the exhuast pipe. i've seen this before w/ebay short shifters. the shifter would sit to low and rattle on the pipe.
Old Oct 10, 2005 | 12:57 PM
TeamNextGenChris's Avatar
first off,there's not a reverse rod.there's the shift rod,and the stabilizer rod.check all the bolts on all that-where the stabilizer bolts to the tranny,where the shift lever bolts to the shift linkage,the bolts that hold the pivot grommet to the stabilizer rod.
also check the grommet that the shift lever rotates in for play,and check the bushing where the stabilizer rod bolts to the tranny for play.if either of those have play,replace them.
also check where the stabilizer rod bolts to the chassis below the shift lever.
Chris
Old Oct 10, 2005 | 02:02 PM
1bad-eg's Avatar
Check to see if it's hitting your exhaust. Did you all ready look under your car?
civic92si
Jun 5, 2012 09:16 PM
loclowd
Oct 10, 2005 12:11 PM
loclowd
Oct 10, 2005 11:40 AM
lsvtec101
May 2, 2003 08:17 AM
Unjockable
Apr 24, 2002 10:13 PM
