Installing Shift Bushings
Re: Installing Shift Bushings (Unjockable)
easy to do. if you are talkin about the shift bushins on the shift linkage then there are only 3 bolts to under. Jack your car up and go under it. on your shift linkage contected to your tranny there should be a 12mm bolt to take off. then slide that stock bushing out and slide your new one in, then go to the middle of the car where you will see your shifter part. there are 2 12mm bolts to take out. then you slide the shift linkage out of the bushing and. put new on on. its like a 7 minute job.
New User
