swaping b16a into a 96 civic coupe
Old Oct 10, 2005 | 12:04 AM
gray_civic_coupe's Avatar
Default swaping b16a into a 96 civic coupe
I have a d16y6 engine in my civic and i'm looking forward for a b16a swap
what are the parts that i need for a complete swap ?
Old Oct 10, 2005 | 04:11 AM
Default Re: swaping b16a into a 96 civic coupe (gray_civic_coupe)
bump!
Old Oct 10, 2005 | 04:42 AM
allmotorteg_96's Avatar
motor mounts and shift linkage
Old Oct 10, 2005 | 12:05 PM
Default Re: swaping b16a into a 96 civic coupe (allmotorteg_96)
dont forget that i have to change the transmission as well !
what else?
Old Oct 10, 2005 | 12:08 PM
bradykiller's Avatar
How bout an ecu conversion harness, and an ECU.
Check out the first 4 topics in this forum, they'll help you out.
Old Oct 10, 2005 | 12:13 PM
tdo's Avatar
tdo
Default Re: swaping b16a into a 96 civic coupe (bradykiller)
this is probably one of the easyer swaps. you shouldnt have too much trouble with it. just go to the FAQ's and look through it, it has more then enough info for this swap your doing and what parts you need. good luck.
Old Oct 11, 2005 | 06:14 AM
Default Re: swaping b16a into a 96 civic coupe (tdo)
thnx guys
Old Oct 11, 2005 | 07:40 AM
hatchi's Avatar
depends what year b16 you are dropping in
Old Oct 11, 2005 | 09:33 AM
doublejz's Avatar
Default Re: swaping b16a into a 96 civic coupe (hatchi)
i know i hate when people tell me this....... but search
Old Oct 11, 2005 | 02:09 PM
eg1point8's Avatar
yes depends on what year b16 ....i put a first gen b16 in my 96 hatch a while back but i went obd2 compliant w/ it ..meaning i put the crank angle sensor in ,knock sensor,00 si intake manifold w/ all sensors attached to it...then i had to rewire my stock harness to accept the knock sensor ,vtec wires,o2 sensor,etc...
jolheat
Jul 22, 2008 10:25 AM
loverboy
Aug 6, 2006 12:33 PM
sleeperH22
Mar 20, 2005 06:58 PM
.ShawnD.
May 5, 2004 07:22 AM
