NEED Help on GSR swap on 97 civic ex
Can i use my harness for the swap? i have a 95 B18C1 i know its obd1 but i plan to buy the obd2 to obd1 harness and use P72 ecu. I can leave the obd1 Distributor right?
I can use LS injectors on a GSR right???
Also where can i buy new oil pump?
Modified by vtec25 at 12:44 AM 10/10/2005
you will need to use your 97 ex wiring harness, wire up knock sensor, iab's.
you will need to cut and resolder injector wires, distributor wires, alternator on the ex wiring harness.
no, no, no. you dont neet to cut anything. lol. waste of harness.
i have a 97 cx with a 94 gsr motor, im using 96-98 EX harness. so beleive me. instead of cutting anything, get a obd2 distributor, there like 50bucks. the obd1 dizzy has 2 plugs i beleive, so you cant use that one. the alternator plug is different, so use your single cam alternator. you need to extend your o2 sensors too.
ohsnapzafingcu
21
Nov 12, 2008 02:22 PM
williebrenn
Aug 13, 2008 03:44 PM
iheartmyej8
Feb 11, 2007 06:30 PM
