either very stupid or very bad
so ill start from the beginning. go out today and finish up cleaning up mpfi wiring on my 88 crx dx. so i loom the four wires from ecu and fix ghetto CAI tb to air tube so i get back in car and start and its missing??????? go pull out plug wires and #1 cylinder spark plug has oil all over it?????? pulled others and nothin go back start up car and its no longer missing but MASS OIL SMOKE is pouring out and theres even beads of oil in the tail pipe. could it just be the oil went in the cylinder from when i pulled the spark plug? ive let it idle for like two minutes and still bad so then i pulled out all spark plugs and #4 had the same thing...........................should i let it idle for a while to c if it stops? drive it to c if its just in the cylinders? o yea and the spark plug igniter tips were not oily they were dry and i pulled valve cover and the rubber spark plug gasket seal things were in good shape.
thanks alot
thanks alot
did you do anything to the head recently? besides the mpfi swap?
I had oil on one of my plugs once, it was just a bad tube seal for the valve cover. I'd check that first.
VTEC_Du_Ma_Mai
Sep 5, 2008 01:41 PM
