99 civic hatch with front gsr brake conversion
Old Oct 8, 2005 | 01:53 PM
99_dc2's Avatar
Default 99 civic hatch with front gsr brake conversion
Will a 97-01 front and back brakes with the hub and the arm fit on a 99 honda civic hatch???
Old Oct 8, 2005 | 01:56 PM
Filliam H. Muffman's Avatar
Default Re: 99 civic hatch with front gsr brake conversion (99_dc2)
SEARCH.
"how do i put x brakes on y car"
there is a massive archive.
Suspension/Brakes:
https://honda-tech.com/zerothread?id=152884 – Putting X Brakes on Y Car
https://honda-tech.com/zerothread?id=514109 – 96-97 JDM ITR 4 Lug Brake Information
https://honda-tech.com/zerothread?id=811892 – ITR 4 Lug onto EK
https://honda-tech.com/zerothread?id=514109 – ITR Brake Thread
https://honda-tech.com/zerothread?id=333061 – Five Lug Conversion
https://honda-tech.com/zerothread?id=1036267 – GSR Suspension into EG
https://honda-tech.com/zerothread?id=812062 – Integra Rear Discs onto EG
https://honda-tech.com/zerothread?id=820484 – Full Brake Swap for EG
https://honda-tech.com/zerothread?id=641639 – EK Rear Disc Conversion
https://honda-tech.com/zerothread?id=641639 – Complete Rear Disc Brake Conversion
https://honda-tech.com/zerothread?id=1030365 – Integra Brake Swap
http://texas.hybridgarage.com/viewtopic.php?t=960 – Changing out Main Rear Trailing Arm Bushings
http://home.socal.rr.com/civic...x.htm - Cutting Away Old Control Arm Bushings and Using New Ones
https://honda-tech.com/zerothread?id=490117 – Tie Rod End Removal
https://honda-tech.com/zerothread?id=1031874 – Changing Tie Rod Ends
http://home.earthlink.net/~civ....html - Bolt and Washer Camber Fix
https://honda-tech.com/zerothread?id=481704 – Jim Fab Traction Bar Install
https://honda-tech.com/zerothread?id=555391 – HX Wheels on GSR or Si
https://honda-tech.com/zerothread?id=861481 – Rear Lower Tie Brace Install
https://honda-tech.com/zerothread?id=972851 – Front Tower Bar Install
https://honda-tech.com/zerothread?id=1079213 – Lower Tie Brace Install
https://honda-tech.com/zerothread?id=1078663 – Coilover Sleeve Install
https://honda-tech.com/zero...age=3 – NSX Calipers
https://honda-tech.com/zerothread?id=864784 – Brake Rotor Replacement
https://honda-tech.com/zerothread?id=1317231 - Quaife Steering into EG
wunfstgsr
Oct 13, 2011 09:45 PM
lil_rob
Suspension & Brakes
Jul 10, 2010 05:50 AM
assassinACE
17
Sep 14, 2006 11:32 PM
Acoupdetat
12
Jan 5, 2004 12:09 AM
