eg b18c1 swap help needed
Old Oct 8, 2005 | 12:21 PM
Hartattack's Avatar
Default eg b18c1 swap help needed
Alright So I have a manual 94 dx hatch. That I am in the process of putting a manual usdm 95 gsr motor (b18c1) in.The engine also has a skunk2 intake manifold on it if that helps. I just pulled my old engine and started to get ready to put it in But I found 2 connectors that I have no idea where they go. The first is a four pin connector located underneath the intake manifold the colors of the wires are orange/black, green, yellow/black, and white/red. I cannot find a place to plug it in, nothing in the engine bay and nothing near it on the motor. The second is a two pin connector located on the transmission side where the main canon plugs are. The wires are yellow/black and red. Again I cannot find anything on the engine to plug it into or anything in the engine bay.
Thanks in advance
Old Oct 8, 2005 | 12:31 PM
crackerjacker006's Avatar
Default Re: eg b18c1 swap help needed (Hartattack)
What wiring harness are you using?
Old Oct 8, 2005 | 12:32 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Helms manual will tell you exactly what these plugs are and what they do.
Old Oct 8, 2005 | 12:33 PM
Hartattack's Avatar
Default Re: eg b18c1 swap help needed (JDM_Ej)
I am using the stock usdm gsr engine harness, which I am trying to plug into the original 94 dx chassis harness.
Okay I think I figured out the two pin connector is the evap purge connector, which I will just hard line to the ecu, this seem correct?
Old Oct 8, 2005 | 01:08 PM
Hartattack's Avatar
I screwed up the 4 pin is the o2 sensor connector, I forgot that it wasn' on the manifold but on the b-pipe im retarded, but I am still unsure about the 2 pin connector.
Old Oct 8, 2005 | 05:25 PM
Hartattack's Avatar
anyone know what that 2-pin connector is?
Old Oct 8, 2005 | 05:35 PM
hatchi's Avatar
is the 2 pin connector round?? can you get pictures?
Old Oct 8, 2005 | 06:18 PM
Hartattack's Avatar
Default Re: eg b18c1 swap help needed (hatchi)
it is not round, its squarish. I can kinda trace the lines back to the evap purge solenoid but the thing is I do not have this connector on my chassis so should I just hard line them using like butt connectors? The red line to a20 on my ecu and the yellow/black to any 12 volt power? The other wierd part is that my sotck dx wiring harness has a wire in a20 for evap purge but I cannot find it in the cannon plugs. So what do you guys think I should do?
Old Oct 8, 2005 | 07:18 PM
Hartattack's Avatar
I guess I will just throw the engine in and see what kind of cel I get
93lambocivic
Jan 17, 2012 07:54 PM
toolow69
Sep 13, 2011 07:07 PM
liloEG
Sep 27, 2010 12:54 PM
Hartattack
Oct 8, 2005 05:26 PM
karmannghia
Nov 26, 2001 08:02 AM
