Engine wiring help..
hey guys im doing my first engine swap...just a quick question..i have a B16a motor but need the engine wiring harness...will i be able use a 96 Gsr engine harness, because isn't the dizzy different? sorry if i could get some help and info about what i can and can not use, or if that harness will work.. thanks
Re: Engine wiring help..
hmmm let me check my crystal ball....nope sorry still broken. year make and model would really help as 92-95 civc's have a two part harness and 96-2000 have a one piece engine wire harness. more info needed
Seagull Management
What OBD is the engine? If its OBD2 yes you can use a GS-R harness, but the IAB and evap purge wiring is switched around at the shock tower plug. If its a JDM B16A don't worry about it, you wont be using either plug, if its a USDM B16A just plug the IAB plug into the purge solenoid.
alacard
01-08-2009 06:06 PM
