Shitty first time at the track with turbo setup
Setup is a 93 Ex with a B16a2 t3/t4 57 trim turbo.... apexi catback 450cc injectors stage 2 clutchmasters, stock 14 inch rims with yoko avs 100s also kyb agx struts all around..... tuned with uberdata @ 9psi.... here it goes....
rt .741
60ft 2.671
330ft 6.819
1/8 9.980
mph 81.35
1000 12.634
1/4 14.829
mph 104.03
I know that my 60ft is to blame but this car should be in the mid 13's....also a humid day and I'm not a very good driver at the track... anyways any feedback would be appreciated.... thanks Mike
flamers welcome.... hahahahahaha..
rt .741
60ft 2.671
330ft 6.819
1/8 9.980
mph 81.35
1000 12.634
1/4 14.829
mph 104.03
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowhonduh »</TD></TR><TR><TD CLASS="quote">Setup is a 93 Ex with a B16a2 t3/t4 57 trim turbo.... apexi catback 450cc injectors stage 2 clutchmasters, stock 14 inch rims with yoko avs 100s also kyb agx struts all around..... tuned with uberdata @ 9psi....
You know the problem, get some better tires or slicks. No point in spending any money to make power if you can't put it to the ground.
victoriasamantha
Oct 16, 2008 03:46 PM
