Shitty first time at the track with turbo setup
Old Oct 8, 2005 | 10:11 AM
1slowhonduh's Avatar
Default Shitty first time at the track with turbo setup
Setup is a 93 Ex with a B16a2 t3/t4 57 trim turbo.... apexi catback 450cc injectors stage 2 clutchmasters, stock 14 inch rims with yoko avs 100s also kyb agx struts all around..... tuned with uberdata @ 9psi.... here it goes....
rt .741
60ft 2.671
330ft 6.819
1/8 9.980
mph 81.35
1000 12.634
1/4 14.829
mph 104.03
I know that my 60ft is to blame but this car should be in the mid 13's....also a humid day and I'm not a very good driver at the track... anyways any feedback would be appreciated.... thanks Mike
flamers welcome.... hahahahahaha..
Old Oct 8, 2005 | 10:20 AM
FRANK_WHITE's Avatar
get that 60ft down try drag radials will help you A LOT
Old Oct 8, 2005 | 10:41 AM
Calvinator's Avatar
Default Re: (FRANK_WHITE)
What rpm are you launching at? Yea, defenitely work on your launches. 2.6 is horrible.
Old Oct 8, 2005 | 11:24 AM
nsxmatt's Avatar
Default Re: Shitty first time at the track with turbo setup (1slowhonduh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowhonduh &raquo;</TD></TR><TR><TD CLASS="quote">Setup is a 93 Ex with a B16a2 t3/t4 57 trim turbo.... apexi catback 450cc injectors stage 2 clutchmasters, stock 14 inch rims with yoko avs 100s also kyb agx struts all around..... tuned with uberdata @ 9psi....
You know the problem, get some better tires or slicks. No point in spending any money to make power if you can't put it to the ground.
Old Oct 8, 2005 | 11:58 AM
yeah i was planning on getting some drag radials next year and see what she does then... hopefully in the 13's.... later mike
victoriasamantha
Oct 16, 2008 03:46 PM
Manny86
Oct 21, 2007 02:13 PM
AaronJ
Oct 13, 2005 11:51 AM
Poop111444
May 24, 2003 07:36 AM
