Do Resonators Only Flow One Way?
Old Oct 7, 2005 | 12:35 PM
litterbox's Avatar
I am a (Trial User) Army
Default Do Resonators Only Flow One Way?
I'm welding up a 22'' Magnaflow Resonator tonight. Does it only flow in one direction? Or can I weld it in to the piping either way?
Old Oct 7, 2005 | 01:03 PM
SMSP's Avatar
Default Re: Do Resonators Only Flow One Way? (litterbox)
I assume you are using a 10436? If so, take a flash light and look down the center. You'll see the center core is a 2 piece with a semi slip joint (male/female). Part of this protrudes slightly into the flow path. You want the inlet of the resonator to be the female side of this joint. When I sell these I usually mark the flow direction.
The 10416, 10426 and 14416 don't matter which direction they are installed.
For the outlet tubing, I knife edge the front edge so there isn't a sharp lip, call me ****.
Old Oct 7, 2005 | 01:08 PM
DonF's Avatar
Default Re: Do Resonators Only Flow One Way? (SMSP)
Hi, ****.
Old Oct 7, 2005 | 01:16 PM
SMSP's Avatar
Default Re: Do Resonators Only Flow One Way? (DonF)
Good one, maybe I should delete it.
Old Oct 7, 2005 | 01:28 PM
litterbox's Avatar
Thanks for that awesome answer Dave. I have the 10436. I see the joint. Thanks!!
buywarbonds
Dec 21, 2018 08:34 AM
Broertje
Mar 2, 2012 07:48 AM
JuggerNuts
Welding / Fabrication
Nov 23, 2006 11:13 PM
seamoss
Apr 21, 2005 06:53 PM
LillDragun
Apr 23, 2002 07:41 AM
