Removing door panels on the EG
if you have manual windows you need to take the little metal clip off that is between the handle and the door panel so it slides off, then remove all the screws, i think there are only 3 then pull, there are clips that hold it on
edit i read you have an ex, you just have to remove the screws then,i think there are 4,just pull done be afraid too, and when putting it back on it will just pop back on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">edit i read you have an ex, you just have to remove the screws then,i think there are 4,just pull done be afraid too, and when putting it back on it will just pop back on</TD></TR></TABLE>
?? where are the 4 screws located? I only found one, the one closest to the dashboard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECsound »</TD></TR><TR><TD CLASS="quote">?? where are the 4 screws located? I only found one, the one closest to the dashboard.</TD></TR></TABLE>
theres one plastic screw that is exposed just below your mirror, and the trick to those plastic screws are to back it out with slight pressure, cause you can press it back in by just pushing on it. back it out enough to get a grip on it, and then back it out til its off with your fingers, then pull on the panel from the top edge, and the clip will pop out of the panel, and you can take it off with your fingers. Theres another screw inside the door latch, another inside the door handle cup, and then you just start pulling the door panel out, starting at the speaker panel cause its thin there, and easy to get your fingers under. work your way along the bottom, til you get to the back side of your door, and by now the panel will be loose. Push up, to lift the panel off of the window ledge, and then lift off slightly, now you can unclip all your electrical stuff from behind. If its not off now, you are the wrong man for the job!
in my lx you remove 3 skrews (im sure u can find those)
then for the door handle/door lock switch you SLIDE it right and undo the door bar thing to take it off, unhook the plug
after that just pull it off, not too hard or too far because u dont want to rip out power window stuff.
litterbox
20
Mar 22, 2006 03:45 PM
shorty0o29
Oct 14, 2003 11:39 AM
