LS/VTEC build questions
Old Oct 5, 2005 | 10:47 AM
Superdragr45's Avatar
Default LS/VTEC build questions
im getting close to putting on my VTEC head, but, i have some quick questions about this build before i begin.................
1). i have a set of B16 head bolts. i was told NOT to use them because they will not be able to torque the head all the way down. can anyone give me some advice on wat to do????
2). the head i have has been milled .040 and i was told it will change the cam timing. do i need to get adj. cam gears to adjust the timing?? also, i retard the timing?? lemme kno on this one.
3). also, when i buy the cam gears, do i buy them for the head im using (B16a) or for the original motor (b18b)? i will be using the LS timing belt.
Old Oct 5, 2005 | 10:59 AM
highrevnef's Avatar
Default Re: LS/VTEC build questions (Superdragr45)
just buy some arp bolts and call it a day for ur second question im not so sure about timing but if ur gonna use a b16 head get cam gears for a b16. hope that helped a little good luck with the build.
Old Oct 5, 2005 | 11:08 AM
CompressionFed's Avatar
Default Re: LS/VTEC build questions (highrevnef)
1>You need to use GSR/TYPE R head studs (ARP, AEBS, etc).
2>When you mill the head, timing can change a little. Any aftermarket BVTEC (TYPE R, GSR, B16) cam gear will work.
3>If you do not have a head gasket yet, a 93 LS headgasket works great! Just buy some LS/VTEC dowls and use a dremel like tool to open up the headgasket.
Good luck!
Old Nov 24, 2005 | 06:42 AM
JDM00SI's Avatar
which timing belt should he use? i have the same question.
Old Nov 24, 2005 | 07:01 AM
D-Rob's Avatar
Default Re: (JDM00SI)
Timing belt choice depends upon water pump choice.
If you're using an LS water pump, run the LS timing belt.
If you use a GSR/ITR water pump, use a GSR/ITR timing belt.
Old Nov 24, 2005 | 07:13 AM
JDM00SI's Avatar
is there a way to ID if its an ls waterpump or gsr/itr water pump?
Old Nov 24, 2005 | 07:32 AM
D-Rob's Avatar
The GSR/ITR water pump is HUGE. The actual gear is physically large.
I can't remember off hand how many teeth there are on each, though...
Old Nov 24, 2005 | 10:17 AM
shattered_dreams's Avatar
Default Re: (D-Rob)
The ls water pump flows more than the gsr/type r i think
Dont worry about the cam gears you dont need them its not worth the money unless u have aftermarket cams
Old Nov 24, 2005 | 07:45 PM
saver's Avatar
Default Re: (shattered_dreams)
shattered dreams you are really wrong about ls pump is much greater.
gsr/type r pump is the best way to go when you doing a b18 or b20 vtec swap . and could tune your stock cams with aftermarket cam gears. he should get them if he really needs to. the gsr/type r pump has a greater velocity then the ls and the b20. and ya arp bolts will stop your worries. o and get the the same timing belt as the same head your using. it has the same teeth as the cam gears and the pump needs.
Old Nov 25, 2005 | 05:03 AM
D-Rob's Avatar
Default Re: (saver)
Head has nothing to do with timing belt, my friend.
I'm using a GSR timing belt with a B16 head on my LSVTEC.
Water pump is the ONLY determining factor on timing belt choice.
Old Nov 25, 2005 | 09:19 AM
saver's Avatar
Default Re: (D-Rob)
any vtec swap is good for the timming belt meaning you did right . i was saying you cant put a ls timming belt on a vtec swap cause it doesnt have anough teeth on them. so if your running a type of vtec head then you should us that pump. and just to thro this comment in umm.. b16 pumps do not have the same velocity as the gsr/type r pumps.
Old Nov 25, 2005 | 10:59 AM
D-Rob's Avatar
Default Re: (saver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saver &raquo;</TD></TR><TR><TD CLASS="quote">any vtec swap is good for the timming belt meaning you did right . i was saying you cant put a ls timming belt on a vtec swap cause it doesnt have anough teeth on them. so if your running a type of vtec head then you should us that pump. and just to thro this comment in umm.. b16 pumps do not have the same velocity as the gsr/type r pumps.</TD></TR></TABLE>
...Uh, no, actually.
The water pump is the ONLY determining factor, as I stated before.
Old Nov 25, 2005 | 11:06 AM
saver's Avatar
Default Re: (D-Rob)
wat are you talking about.
Old Nov 25, 2005 | 11:29 AM
D-Rob's Avatar
Default Re: (saver)
You mentioned about adding 'VTEC swap' to the LS block, and using a VTEC timing belt.
Adding a VTEC head doesn't mean you need a VTEC timing belt.
If you were to do an LSVTEC with LS block and a GSR head, if you still are using the LS water pump, you would use the LS timing belt.
Old Nov 25, 2005 | 11:36 AM
saver's Avatar
Default Re: (D-Rob)
the part where your talking about the ls pump and wat not. is wat im talking about. witch ever pump your using has to match thet timming belt unless its a vtec
but i was told that wich ever vtec swap your using has to match the belt. for an example. if your using a vtec cam gears then you got to match that with the belt, correct? thats wat i was told by honda tuning. i hope i made sence for you to understand wat im talknig about.
Old Nov 25, 2005 | 11:45 AM
D-Rob's Avatar
Default Re: (saver)
Actually, that is incorrect.
VTEC cam gears are the same as LS ones.
Old Nov 25, 2005 | 12:00 PM
saver's Avatar
Default Re: (D-Rob)
really,so they are changeable
Old Nov 25, 2005 | 12:25 PM
saver's Avatar
d rob i check out your motor. your runing low numbers. is it cause your not running aftermarket cams and is your motor tuned yet?
Old Nov 25, 2005 | 12:51 PM
D-Rob's Avatar
Default Re: (saver)
Low numbers?
You mean the dyno numbers? That was with stock cams.
If you're talking about the track times, remember, that was at an uphill track in a heavy coupe with full interior and a stereo.
Old Nov 25, 2005 | 01:05 PM
saver's Avatar
Default Re: (D-Rob)
hey do you have sn for aim? wat coupe an 92-95 or 96-98
jdmdikk
23
Sep 26, 2008 05:13 PM
rated_r
Feb 1, 2008 05:28 PM
Bevin
Sep 19, 2006 11:01 PM
blowme
Nov 11, 2005 11:40 PM
sikcrx80
Mar 25, 2004 05:12 PM
