Blue smoke at idle - need help!!
Old Oct 5, 2005 | 10:31 AM
99TurboFerio's Avatar
Default Blue smoke at idle - need help!!
I need some help figuring out what could be the problem exactally... I have had this problem for about 3 weeks now with my d16 turbo.
My car will start up fine and warm up but once it reaches about half way to normal temp it starts to smoke out the exhaust its blueish and smells like oil for sure. I have a brand new head gasket in it and my compression is fine. So im thinking its a seal on the turbo or my oil return line isn't flowing well enough. Its ONLY during idle and it stops after I'm driving in or out of boost. Just wondering if anyone else has had this happen and what they did to fix it like a full rebuild, taking it apart to just replace the seals or if i need to replace the whole charger. I've never rebuilt a turbo so idk if i can just take it apart and clean it and swap out some seals and or gaskets. Help would really be good it looks weak driving around and smoking people out at stoplights. Thanks-
Old Oct 5, 2005 | 03:13 PM
boost'dsiR's Avatar
Default Re: Blue smoke at idle - need help!! (99TurboFerio)
its kinda happening to me and every one is saying that too much oil pressure is goin in to the turbo
Old Oct 5, 2005 | 04:22 PM
TheIntegraGuy's Avatar
Default Re: Blue smoke at idle - need help!! (boost'dsiR)
Does it smoke in idle at all times? Could be too much pressure going to your turbo. If you have a -4 feed line, use a reducer or change to a -3. It could easily be a kinked oil return line as well which I would guess. Be sure to find the problem soon before the oil blows through the seals.
Old Oct 6, 2005 | 09:37 AM
boost'dsiR's Avatar
Default Re: Blue smoke at idle - need help!! (TheIntegraGuy)
i think its too late for me
boost'dsiR's Avatar
is there ne smaller line the a 3-
Old Oct 6, 2005 | 10:28 AM
Importordomestic's Avatar
most turbochargers dont need to see any more oil pressure higher than 30psi
Old Oct 6, 2005 | 11:19 AM
boost'dsiR's Avatar
Default Re: Blue smoke at idle - need help!! (Importordomestic)
ive heard but i think its too late soo im lookin for a manifold and turbo and down pipe thats all if ne body got ne . plz hit me up thanks
Old Oct 6, 2005 | 01:28 PM
fmfkid250's Avatar
turbo seals/bearings going give it 2 months and it will do it all the time, just get new/seals/bearings and fire em in and good as new,
turbo timer will help prevent from duing again
Old Oct 6, 2005 | 02:38 PM
boost'dsiR's Avatar
Default Re: Blue smoke at idle - need help!! (fmfkid250)
its been rebuilt so many times already tho
Old Oct 11, 2005 | 08:12 AM
ya i think its a little late for my turbo also. Ive taken it apart and its gone past the seals. The rest of the turbo looks good tho- can i replace the seals and whatever else that i need to with out taking it to a shop to get a rebuild? the Oil outlet flange also cracked from heat and stress it looks like so ill be replacing that first but i dont think that would contribute to the smoke since its not putting any resistance on the oil thats draining ... its just draining on the road instead of my pan Any info like a website or anything like that would be great about turbo rebuilds or being able to replace parts w/o a rebuild
Thanks in advance-
Old Oct 12, 2005 | 01:32 PM
boost'dsiR's Avatar
im just gonna buy a brand new turbo and stop messin wit rebuilt ones.
Old Oct 13, 2005 | 12:06 AM
got the flange.. Turbo Technology in Tacoma .... doesn't leak n e more and it smokes about 90% less since ive cleaned it so hopefullly it lasts me till i can get money 4 a new turbo
Old Oct 13, 2005 | 03:02 PM
yee SERIOUS's Avatar
sounds good. if i saw this thread earlier i would've recommended turbo tech too. my old high school shop was tellin me about a shop that is in federal way now i think. it's called Bay Engines. and i guess they sell rebuild kits and stuff. it's a semi-truck store. but coolio....if you're getting too much oil. you should run a restrictor.
hammerj2
Mar 18, 2010 06:24 AM
B20luda
Sep 16, 2004 08:41 AM
Boostless97Lude
Feb 1, 2003 08:44 PM
kickz
Aug 8, 2002 09:37 PM
EMod Civic
Oct 28, 2001 05:23 PM
