How much you think a 2" reducer effects spool time?
Old Oct 5, 2005 | 06:59 AM
turbotime's Avatar
Default How much you think a 2" reducer effects spool time?
I have this crap DRAG downpipe, it is 2.5" all the way down then they put a 2" reducer at the very end to make it fit a stock cat
I was wondering how much you think this effect my spool time. Here is my setup:
DRAG 2.5" downpipe -> 2" reducer -> 2.5"-3" high flow cat -> 3" kteller all the way back.
I dont see full boost til around 4-5k, think removing the reducer will cut down my spool time?
Thanks
Old Oct 5, 2005 | 08:17 AM
95GSRTT
Guest
Posts: n/a
Default Re: How much you think a 2" reducer effects spool time? (turbotime)
by alot!
Old Oct 5, 2005 | 08:32 AM
turbotime's Avatar
damn! need to get it removed asap then!
Old Oct 5, 2005 | 08:43 AM
95GSRTT
Guest
Posts: n/a
Default Re: (turbotime)
by getting rid of that reducer you will gain spool and power. If I were you I would change the cat out to a straight 3" and flare out your DP to 3" too if that is a possibility. GL
Old Oct 5, 2005 | 08:51 AM
turbotime's Avatar
money money money
i got a buddy who can cut and weld the downpipe but i just blew 150 on the cat so i will have to stay 2.5" - 3" for now, but yeah i gotta get that reducer removed.
asap
Old Oct 6, 2005 | 12:13 PM
yee SERIOUS's Avatar
how is your cat setup? if it's like most, you had someone weld on a pipe to it right? so can't you cut that pipe off and weld on a 3inch pipe? and then get new flanges to match the dp to the cat?
or maybe....3inch test pipe?
Old Oct 6, 2005 | 12:31 PM
turbotime's Avatar
i have a kteller 3" exhuast with a kteller 3" -> 2.5" conversion cat. My downpipe is 2.5" all the way to the cat except for some retarded reason DRAG welded a 2" reducer in the end so i need to cut off the whole flange and get a 2.5" flange welded back on..
Old Oct 6, 2005 | 01:02 PM
m R g S r's Avatar
cut it and run open downpipe
Old Oct 6, 2005 | 01:21 PM
turbotime's Avatar
Default Re: How much you think a 2" reducer effects spool time? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">cut it and run open downpipe</TD></TR></TABLE>
right, after spending $600+ on my exhaust im just gonna cut my downpipe and trash the exhaust
ludegirl1004
Jul 17, 2003 06:56 PM
HondaCutter
Mar 31, 2003 03:20 AM
Halive
10
Apr 9, 2002 09:24 AM
Reverend
Aug 26, 2001 07:34 AM
