Severe lag. Is this turbo too big or is something else wrong? (GT2854R on DOHC ZC)
Old Oct 4, 2005 | 09:04 PM
Blindstuff's Avatar
Default Severe lag. Is this turbo too big or is something else wrong? (GT2854R on DOHC ZC)
So, just as the title says, i just finished instaling a GT2854R (Info about turbo here: http://www.turbobygarrett.com/...9.htm) on my DOHC ZC. The car was not boosting at all with the wastegate atached, i would get about 1 psi all the way to the redline, so i went and gave it a shot to see if the wastegate was really closed. I tied it shut with metal wire. Now, i was guessing i would get about 15 psi in 2nd gear in no time, so i went at it real slow, just to see if it was boosting.
Heres the deal:
from 1000 to 4000 I get 1 psi
from 4000 to 5500 I get 5 psi
and from 5500 to 7200 it jumps quickly to 7 psi and there on creeps slowly to 9 psi.
THe wastegate is COMPLETELY shut, i tied it down very well.
So, am i just using the wrong turbo or do you think there might me something inside the turbo thats not letting it spool how it should.
Old Oct 4, 2005 | 09:07 PM
stockredej1's Avatar
Default Re: Severe lag. Is this turbo too big or is something else wrong? (Blindstuff)
Check your IC piping, that would be my guess, something isnt tight. if not i have no idea, good luck man
Old Oct 4, 2005 | 09:11 PM
Blindstuff's Avatar
Default Re: Severe lag. Is this turbo too big or is something else wrong? (stockredej1)
I thought of that, but there is no damage to the piping and i've checked all the couplers a million times...
Old Oct 4, 2005 | 09:22 PM
Blindstuff's Avatar
Engine is stock internally, well, it has a HKS 0.7mm Headgasket with about 10:1 compression and ARP head studs. DOHZ ZC's come stock on Si Sedan Civics here in venezuela, im runing a P29 computer (also came stock.) on the blue box temporally, crome is going to replace that in a couple of weeks.
I had a diferent turbo before (TD04) but i has a pretty different setup(that one held boost under the same engine specs), the things that have changed include manifold, part of the charge piping, BOV and DP.
Old Oct 4, 2005 | 09:38 PM
SOHCmaster's Avatar
If you turned up the boost to 15-20 psi the turbo will come alive
Old Oct 5, 2005 | 07:29 AM
Blindstuff's Avatar
Default Re: (PK SPEED)
How am i going to turn up the boost if the wastegate is just held ****. I doesnt ever open at all
Old Oct 5, 2005 | 07:54 AM
ginoboy1978's Avatar
Default Re: (Blindstuff)
If the wastegate is held shut, wouldn't your turbo be taking the max amount of boost (ie. overspooling)?
DAN
Old Oct 5, 2005 | 08:10 AM
95GSRTT
Guest
Posts: n/a
Default Re: (ginoboy1978)
lol ya someone needs to research some more on wastegates . What spring do you have? and have you checked the diaghram for any rips? What intercooler are you running? and what manifold?
Modified by 95GSRTT at 5:51 PM 10/5/2005
Old Oct 5, 2005 | 08:17 AM
Blindstuff's Avatar
Default Re: (95GSRTT)
Thats the deal, if there are no leaks, because i confirmed this and the wastegate is shut then why the f*ck doesnt boost start to go up like crazy.
This is the only GT28 that is internally wastegated, but when i said i tied it down i mean I held it with a piece of metal. BElive me it doesnt move at all.
Civic HF manifold and Modified DSM 1g intercooler
Old Oct 5, 2005 | 08:49 AM
beepy's Avatar
You have a leak somewhere. They can be a bitch to find sometimes. Once I had a rip up the side of the coupler that connected my charge pipe to my throttle body. The rip wasn't visible by visual inspection, only by bending the coupler did I see it.
Old Oct 5, 2005 | 10:42 AM
Ace.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED &raquo;</TD></TR><TR><TD CLASS="quote">If you turned up the boost to 15-20 psi the turbo will come alive</TD></TR></TABLE>
Why would you say that???
This turbo's 'range' is commonly known to hae a roof of around 250/260 hp....
At 15 psi, this thing would probably be off the compressor map
Old Oct 6, 2005 | 03:10 AM
D@nnY's Avatar
Default Re: (AceAltima)
is the car tuned?
Old Oct 6, 2005 | 07:46 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blindstuff &raquo;</TD></TR><TR><TD CLASS="quote">Now, i was guessing i would get about 15 psi in 2nd gear in no time, so i went at it real slow, just to see if it was boosting.
Heres the deal:
So, am i just using the wrong turbo or do you think there might me something inside the turbo thats not letting it spool how it should.</TD></TR></TABLE>
You're not giving it much gas and looking for boost? If you don't give it a lot of throttle you won't build boost as much or at all.
Sounds like something is wrong with your wastegate perhaps?
Old Oct 6, 2005 | 09:12 AM
mstolars's Avatar
Might have leaks in the charge piping/intercooler, exhaust system could be severely plugged up somewhere. Maybe try pulling off the downpipe and run it completely open. You should be building a lot more boost a lot faster. Also check if the turbo intake isn't blocked off too much, i heard of guys putting a rag around it to make a ghetto air filter and the car wouldn't boost much at all because of intake air restriction. Hope this helps
Old Oct 6, 2005 | 09:28 AM
warrick's Avatar
Default Re: Severe lag. Is this turbo too big or is something else wrong? (mstolars)
check for leaks between the head and the turbo.
Old Oct 6, 2005 | 04:21 PM
Blindstuff's Avatar
Default Re: Severe lag. Is this turbo too big or is something else wrong? (warrick)
Im going to check everything you said. Seems i´l have to pull the turbo kit apart.
The car is not tuned yet, im runing blue box as a temp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">You have a leak somewhere. They can be a bitch to find sometimes. Once I had a rip up the side of the coupler that connected my charge pipe to my throttle body. The rip wasn't visible by visual inspection, only by bending the coupler did I see it.</TD></TR></TABLE>
Might just change ALL the couplers
thanx for the help
mrchris1979
Oct 17, 2005 01:39 AM
crxzcracer
Aug 22, 2004 07:52 AM
AbaZ
Sep 16, 2002 07:36 PM
-=TWITCH=-
Mar 10, 2002 12:15 PM
