Mase sent me a new timing map for the fall national race this weekend and
Old Oct 4, 2005 | 10:28 AM
underpressure02's Avatar
Default Mase sent me a new timing map for the fall national race this weekend and
I only got second place in my class. I want my money back.
But seriously I think my thermostat is stuck closed. Last night after driving home I pulled into my driveway and noticed that I was leaking some coolant from the over flow tank. The tank was filled to the top and the lower rad hose feels like it is empty. The rad was filled to the top though. My temp gauge did not go above normal and the car seemed fine. I am going to drain the system tonight and pull the thermostat, but I just wanted to see what kind or thermostat you guys are running and what temp?
Let me know thanks.
Old Oct 4, 2005 | 10:33 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Mase sent me a new timing map for the fall national race this weekend and (underpressure02)
Stock stat here.
Run the same temp stat as you do switch.
Congrats on 2nd place
Old Oct 4, 2005 | 10:37 AM
Default Re: Mase sent me a new timing map for the fall national race this weekend and (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">Stock stat here.
Congrats on 2nd place </TD></TR></TABLE>
Can i just get one at autozone? Or should I run honda oem?
Old Oct 4, 2005 | 10:39 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">Can i just get one at autozone? Or should I run honda oem?</TD></TR></TABLE>
Im sure autozone would be fine but the OEM one will last longer.
Make sure the one you buy has a little hole in it with that little thing inside. Know what im talking about?; So the air wont get trapped.
Old Oct 4, 2005 | 10:40 AM
Turbo_Mike's Avatar
I just had this same problem with my car the other day. Usually it overheats on the highway and this day it didnt. got home and noticed this - Poured the overflow tank back into the rad and it seems to be normal since... ?
Old Oct 4, 2005 | 10:48 AM
Default Re: Mase sent me a new timing map for the fall national race this weekend and (MIKE JONES)
Yeah its wierd. I have not had an issue with it for the past 2.5 years. Raced all weekend even had a bunch of back to back runs and not one problem. Then yesterday after I got home, I saw i was leaking something, poped the hood and saw the overflow tank was filled. So I am just assuming the theromostat finally took a dump and is stuck closed. Not sure why it did not get hot or overheat.
Old Oct 4, 2005 | 07:38 PM
miamidamian's Avatar
head gasket
Old Oct 5, 2005 | 04:26 AM
i my honda
Global Mod
Default Re: Mase sent me a new timing map for the fall national race this weekend and (miamidamian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miamidamian &raquo;</TD></TR><TR><TD CLASS="quote">head gasket</TD></TR></TABLE>
Not...
Dumbass
If it were the headgasket the overflow tank would most likely be empty or milky.
bow tie
Jun 25, 2008 02:38 PM
brokenojoke
14
Jan 14, 2008 07:37 PM
Ecugrad
Jan 23, 2005 09:57 PM
allmotor.net
Apr 24, 2003 02:58 AM
9K
Jan 7, 2002 05:16 PM
