Engine acting up again
Old Oct 4, 2005 | 07:22 AM
ocks's Avatar
Default Engine acting up again
So last night I was taking a turn, put it in 2nd gear, gave it gas and then all of a sudden the car yanked, and the idle slowly started to drop down to 400 rpms. When I tried to give it gas, it was barely responding. I'd give it gas, but it would only rev up to 2000 and then just not respond. I pulled over to a parking lot, and when I tried to start the car, it'll start up, then the idle drops and then engine cuts off. Anyone know what the problem could be?
Old Oct 4, 2005 | 07:29 AM
IHateJDM's Avatar
Default Re: Engine acting up again (ocks)
take off the distributor cap and see if there is brown dust all over the inside of the cap.
Old Oct 4, 2005 | 07:56 AM
ocks's Avatar
Default Re: Engine acting up again (IHateJDM)
Nope. There isn't any dust at all. The cap and rotors were just replaced 2 weeks ago.
Old Oct 4, 2005 | 07:58 AM
JDM-EJ1's Avatar
Fuel pump?
Old Oct 4, 2005 | 08:02 AM
ocks's Avatar
<<< I'm a straight noob. I have no idea how I'd go and check the fuel pump. Where do I start?
Old Oct 4, 2005 | 08:40 AM
ocks's Avatar
Default Re: (ocks)
Anyone else have any ideas?
Old Oct 4, 2005 | 08:41 AM
00CivicGirl's Avatar
Default Re: (ocks)
well if you should hear a click when you turn the key to start the car..normall the click comes from the rear under the back seats or in that general area. ify fou hear the click, i would say your fuel pump is gettin power
Old Oct 4, 2005 | 08:46 AM
JDM-EJ1's Avatar
Default Re: (00CivicGirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00CivicGirl &raquo;</TD></TR><TR><TD CLASS="quote">well if you should hear a click when you turn the key to start the car..normall the click comes from the rear under the back seats or in that general area. ify fou hear the click, i would say your fuel pump is gettin power</TD></TR></TABLE>
What?
When you turn your key to accessory.. You should hear a 'humming' come from your backseats. Try to have someone turn your key, while you put your hear to your backseats. If you hear the humming, that means your fuel pump is priming and working correctly.
Old Oct 4, 2005 | 08:55 AM
Default Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
What?
When you turn your key to accessory.. You should hear a 'humming' come from your backseats. Try to have someone turn your key, while you put your hear to your backseats. If you hear the humming, that means your fuel pump is priming and working correctly.</TD></TR></TABLE>
humming, clicking whatever..ive done it before when our old eg wouldnt start but mine gets wacked out at work to even type it right
but yea its a humming noise not a clicking sorry
Old Oct 4, 2005 | 09:01 AM
ocks's Avatar
Ok when the key was turned to acc, I heard a humming noise that lasted about 2-3 seconds
Old Oct 4, 2005 | 09:04 AM
Default Re: (ocks)
thats your fuel pump..that means its working so i would rule that out
Old Oct 4, 2005 | 09:11 AM
ocks's Avatar
Alright. What else would be it then?
Old Oct 4, 2005 | 09:41 AM
Default Re: (ocks)
u said the cap and rotor were replaced 2 weeks ago, what about the ignition coil? do you have any friends with the same motor as you? if so, see if they will let you borrow their dizzy and swap em out and see if it works then
Old Oct 4, 2005 | 09:54 AM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Timing belt could have jumped a tooth. This could explain why the motor still starts but dies, and why after the "jerk" you couldn't get anything above 2K rpm..
Just by reading this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ocks &raquo;</TD></TR><TR><TD CLASS="quote">&lt;&lt;&lt; I'm a straight noob. I have no idea how I'd go and check the fuel pump. Where do I start?</TD></TR></TABLE>
Take it to a shop..
Old Oct 4, 2005 | 10:29 AM
ocks's Avatar
The car did this before and I took it to a mechanic that was a friend of a friend. He replaced the cap and rotor and it then ran fine for him. That was two weeks ago, and now I'm back to where I started. But now I got no money for a mechanic. I was hoping it was a easy fix, the hard part was just pinpointing the problem.
Old Oct 4, 2005 | 10:44 AM
Default Re: (ocks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ocks &raquo;</TD></TR><TR><TD CLASS="quote">The car did this before and I took it to a mechanic that was a friend of a friend. He replaced the cap and rotor and it then ran fine for him. That was two weeks ago, and now I'm back to where I started. But now I got no money for a mechanic. I was hoping it was a easy fix, the hard part was just pinpointing the problem.</TD></TR></TABLE>Yeah thats odd that it would work for 2 weeks and just fail again. Either the parts failed again or that wasn't a complete fix of the problem. So I doubt it will be the easy fix you were hoping for.. It could be anything from the ignition control module to the ECU. Your fuel pump is priming so thats good. I'm thinking its gotta be somewhere in the distributor. Ignition control module, crankshaft position sensor, top dead center sensor, cylinder position sensor. I would say find a buddy that you could borrow a distributor from to see if replacing something in the dist. fixes the problem. But whatever it is it will take some $ to fix when it comes down to it..
Old Oct 4, 2005 | 10:57 AM
ocks's Avatar
Default Re: (HondaFanatic708)
Man.. well that sucks. Is there any conflicts when putting a gsr distributor onto a B16? Thats probably the only thing I bum from a friend. Oh and by the way, I really do appreciate everyone's knowledge and help.
Old Oct 4, 2005 | 11:00 AM
Default Re: (ocks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ocks &raquo;</TD></TR><TR><TD CLASS="quote">Man.. well that sucks. Is there any conflicts when putting a gsr distributor onto a B16? Thats probably the only thing I bum from a friend. Oh and by the way, I really do appreciate everyone's knowledge and help.</TD></TR></TABLE>No conflicts as long as they are both the same OBD. Otherwise the connectors don't match up..
Old Oct 4, 2005 | 11:08 AM
ocks's Avatar
Then I guess I'll just have to wait on my friend. Thanks again for the help.
TruEM1
Dec 10, 2013 08:52 PM
kegan88
Classic Hondas
Dec 30, 2011 10:49 AM
StolenTeg
Apr 21, 2005 08:02 AM
Rex_Ryder
11
Apr 1, 2005 02:48 PM
cooljerk187
Feb 26, 2004 12:42 PM
