Clutch/Flywheel Swap Can't get the axels off. *searched*
I have the jar jacked up, Wheels are off and the axel nut is off. I removed the pins and the nut from the lower bolt on the brake assemblies. The problem I'm having is that the lower bolt will not seperate from the LCA on either side, it should be coming free but it seems like it is seized together. I've spent the last 5 hours hammering and prying and pulling every direction, this thing isn't gonna budge. What's next? Is there any tools that I can use to push the bolt up through the LCA so that I can swing the brake assembly aside?
When all else fails bring out the pickle fork and a large hammer. Of course that trick really does a number on your ball joints.
SC0TT
Jul 23, 2003 05:21 PM
