noob...valve adjustment
Old Oct 2, 2005 | 04:53 PM
Cypher0117's Avatar
Default noob...valve adjustment
ok...im pretty sure i need a valve adjustment. at idle i hear a ticking sound...Don't notice it at higher rpms but i definatly hear it at idle. Is this indication i need a valve adjustment?
btw my motor is d15b7 w/ 164k miles
don't know if previous owner ever did vavle adjustment or anything else. I think it might be due. If so i couldn't find the clearances for my motor anywhere.
thanks in advance
Old Oct 2, 2005 | 04:56 PM
AbitAvenger's Avatar
go buy a helms manual, get some tools, and go at it
Old Oct 2, 2005 | 05:15 PM
EGmikeH22's Avatar
* B A N N E D *
helms or chilton or search even.
and yea just make sure to read a write-up to avoid doing it more than once, the engine has to be TDC on the power stroke for the cylinder you are doing (for an H22 at least)
Old Oct 2, 2005 | 05:31 PM
Cypher0117's Avatar
Default Re: (EGmikeH22)
so im guessing by the responses that you think i deffinatly need a valve adjustment?
Old Oct 2, 2005 | 05:36 PM
m00nr0ck Si's Avatar
Default Re: (Cypher0117)
could'nt hurt to do one , even if it does not need it, just a peace of mind. its not difficult , just dont get in any kind of hurry.
Old Oct 2, 2005 | 06:04 PM
Cypher0117's Avatar
Default Re: noob...valve adjustment (Cypher0117)
would anyone happen to know the specs for the valves for my motor? in the search i see a lot for other motors but not mine
Old Oct 2, 2005 | 07:19 PM
Proglow3's Avatar
Intake valves 0.007-0.009
Exhaust valves 0.009-0.011
That's straight out of a manual, You should think about getting your own though.
Old Oct 2, 2005 | 07:25 PM
Dwight Schrute's Avatar
Default Re: noob...valve adjustment (Proglow3)
https://honda-tech.com/zerothread?id=1305086
Old Oct 2, 2005 | 07:52 PM
civic_driver's Avatar
yeah, it's a good idea to do it... it's easy as hell... make sure your engine is cold before you do any adjustments... allowing the engine to cool down overnight is the best thing to do
i just did mine with intake 0.007 and exhaust 0.009... the engine runs smooth at 160K miles!
check out the tutorial above for a howto
ArmaanOG
Dec 28, 2009 01:46 PM
^jefs0ng
Oct 29, 2003 10:38 PM
SpoogenJay
Aug 9, 2003 12:53 PM
g2style
Feb 5, 2003 01:57 PM
h46it
Apr 3, 2002 09:09 PM
