Will kyb gr2s for 96-00 work on my 93 civic
Old Oct 2, 2005 | 03:35 PM
DAVE15401's Avatar
Default Will kyb gr2s for 96-00 work on my 93 civic
The tital says it my friend is getting rid of his kyb but thet are on his 97 will they work on my 93 im 99% sure they would but a little extra might help me lol and if they do fir they make the ride any stiffer then in his car or they should be the same
thanks in advance
Old Oct 2, 2005 | 04:38 PM
vsmhatched's Avatar
Default Re: Will kyb gr2s for 96-00 work on my 93 civic (DAVE15401)
i think they are different like from 92-95 is the same and then 96-00 is the same, I don't think they will work.
Old Oct 2, 2005 | 04:40 PM
SiFan's Avatar
They'll fit with know problem.
Old Oct 2, 2005 | 04:48 PM
B_CRUZ!'s Avatar
Default Re: Will kyb gr2s for 96-00 work on my 93 civic (SiFan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiFan &raquo;</TD></TR><TR><TD CLASS="quote">They'll fit with know problem. </TD></TR></TABLE>
false. you will need to trim your rear LCA bushings on the 92-95 Civic's. The 92-95 Civic LCA rear bushings are about 10mm longer than the 96-00.
Old Oct 2, 2005 | 05:02 PM
DAVE15401's Avatar
Default Re: Will kyb gr2s for 96-00 work on my 93 civic (b_cruz)
ok thanks i thought they would but wasnt 100% .I thought the lca bushing was larger but wasnt sure that why i ask
Old Oct 2, 2005 | 05:26 PM
SiFan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_cruz &raquo;</TD></TR><TR><TD CLASS="quote">
false. you will need to trim your rear LCA bushings on the 92-95 Civic's. The 92-95 Civic LCA rear bushings are about 10mm longer than the 96-00.</TD></TR></TABLE> NOT FALSE!!! The question was "will they work" not whether there was any modification required. I realy dont remember a "10MM" diference when I did the same thing on my 93! Have fun with the swap!!
Old Oct 2, 2005 | 07:16 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiFan &raquo;</TD></TR><TR><TD CLASS="quote"> NOT FALSE!!! The question was "will they work" not whether there was any modification required. I realy dont remember a "10MM" diference when I did the same thing on my 93! Have fun with the swap!! </TD></TR></TABLE>
and your reply was...
but there is a problem.
Old Oct 2, 2005 | 09:19 PM
areyoujealous's Avatar
fronts match right up
rear integra ones will work
Old Oct 2, 2005 | 09:28 PM
shyboi4u's Avatar
Default Re: Will kyb gr2s for 96-00 work on my 93 civic (bling bling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bling bling &raquo;</TD></TR><TR><TD CLASS="quote">
fronts will work but you won't have the brackets that hold the brake lines for the 92-95 civic.
Sleepy_Red_hatch
16
May 27, 2007 07:38 PM
B16B_coupe
Suspension & Brakes
Aug 22, 2006 04:33 PM
1POINT8VTEC
Jan 24, 2006 12:06 PM
zephyrantes
Jul 12, 2005 07:20 PM
Shongku
Aug 5, 2004 09:14 PM
