Will kyb gr2s for 96-00 work on my 93 civic
The tital says it my friend is getting rid of his kyb but thet are on his 97 will they work on my 93 im 99% sure they would but a little extra might help me lol and if they do fir they make the ride any stiffer then in his car or they should be the same
thanks in advance
thanks in advance
Re: Will kyb gr2s for 96-00 work on my 93 civic (SiFan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiFan »</TD></TR><TR><TD CLASS="quote">They'll fit with know problem. </TD></TR></TABLE>
false. you will need to trim your rear LCA bushings on the 92-95 Civic's. The 92-95 Civic LCA rear bushings are about 10mm longer than the 96-00.
Re: Will kyb gr2s for 96-00 work on my 93 civic (b_cruz)
ok thanks i thought they would but wasnt 100% .I thought the lca bushing was larger but wasnt sure that why i ask
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_cruz »</TD></TR><TR><TD CLASS="quote">
false. you will need to trim your rear LCA bushings on the 92-95 Civic's. The 92-95 Civic LCA rear bushings are about 10mm longer than the 96-00.</TD></TR></TABLE> NOT FALSE!!! The question was "will they work" not whether there was any modification required. I realy dont remember a "10MM" diference when I did the same thing on my 93! Have fun with the swap!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiFan »</TD></TR><TR><TD CLASS="quote"> NOT FALSE!!! The question was "will they work" not whether there was any modification required. I realy dont remember a "10MM" diference when I did the same thing on my 93! Have fun with the swap!! </TD></TR></TABLE>
and your reply was...
but there is a problem.
Re: Will kyb gr2s for 96-00 work on my 93 civic (bling bling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bling bling »</TD></TR><TR><TD CLASS="quote">
fronts match right up
rear integra ones will work
fronts will work but you won't have the brackets that hold the brake lines for the 92-95 civic.
Sleepy_Red_hatch
16
05-27-2007 07:38 PM
1POINT8VTEC
01-24-2006 12:06 PM
zephyrantes
07-12-2005 07:20 PM
Shongku
08-05-2004 09:14 PM
