Went to the track yesterday
i had a super shitty day...first time at the track and first time ever running with slicks and a good clutch
first run i was barely moving off the line and rolled out with a 3.1 60ft and managed a whopping 15.7@97 mph
fixed a few things then went back for a 14.5@100 mph with a 2.7 60ft
worked on a few tihngs again and went back to back times of 14.1@102 mph with a 2.5 60ft
next run i broke the axle right inside of the tranny so i got fucked but managed to place 3rd in sport compact power adders due to other cars ******* up
setup is
d16z6 in a 90 ef hatch full interior with jack etc...obd1
chipped p28
td05h...hf manifold
tial bov
2.5 charge pipes and dp
everytihng else stock
also running 14 psi of boost....
1st gear burnouts suck
setup is
chipped p28
td05h...hf manifold
tial bov
my first launch was a 1000 rpm launch lol because i wasnt ready at all then i tried the 2 step and it was set too low at 4400 so i still bogged
then at 5500 it was good but i donno
tire pressure was about 15 psi and yeah i wish i would have been able to get a full pass with a 2nd gear burnout
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic »</TD></TR><TR><TD CLASS="quote">my first launch was a 1000 rpm launch lol because i wasnt ready at all then i tried the 2 step and it was set too low at 4400 so i still bogged
tire pressure was about 15 psi and yeah i wish i would have been able to get a full pass with a 2nd gear burnout</TD></TR></TABLE>
Use the waterbox for a second gear burnout, try lowering the slick pressure a couple pounds and launch at 6000-6500rpm. I did this on my first try with my 22x8x13 slicks and cut a 1.86 60'. No broken axel yet either.
https://honda-tech.com/zerothread?id=1390865
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">wheel hop probubly killed the axle...fyi. </TD></TR></TABLE>
Yeah the wheel hop might be from bogging on the launch. Normally slicks don't wheel hop bad like street tires though.
kinda wanted mid 13's which i can see with my mph is somewhat possible but yeah i used the water box but yeah never got a chance to run with the 2nd gear burnout...but my whole kit cost me about 1200 canadian so regardless what i ran i couldnt lose
anyone else running 15 psi on stock d series engine
I'm running 15 psi from t3/t4 50trim on a OEM internaled d16! I made the mistake of running that much boost on some crappy falken Ziex passenger tire and managed a 14.4... Then ran a 14 flat @ 10psi. it was stupid...
</TD></TR></TABLE>I'm running 15 psi from t3/t4 50trim on a OEM internaled d16! I made the mistake of running that much boost on some crappy falken Ziex passenger tire and managed a 14.4... Then ran a 14 flat @ 10psi. it was stupid...
nice nice...its all in the tune my brother is running 14 psi on his stock d16z6 with a sc50 .60 .63
everyday now its going to kill me that i dont know what i would have been able to do with a good 60 ft
-slow ej-
23
Jul 31, 2004 06:14 AM
Nextelbuddy
23
Oct 4, 2003 02:46 PM
Adi Radoncic
Sep 1, 2002 11:37 PM
