ATTN: 92-95 Hatch w/ Integra Cluster
Old Oct 2, 2005 | 01:28 PM
B-SerioUs EGg's Avatar
B A N N E D
Default ATTN: 92-95 Hatch w/ Integra Cluster
did any of ya have a problem with the gas guage reading incorrectly?
if you did, what did you do?
stuck in the middle of the road w/ no gas
Old Oct 3, 2005 | 05:31 AM
B A N N E D
Default Re: ATTN: 92-95 Hatch w/ Integra Cluster (Frosty R81)
TTT
anyonE?
Old Oct 3, 2005 | 08:33 AM
riceburnerryan's Avatar
your cluster may be bad... ?? check the connections again when i first did the swap i wired my tach up wrong and it didnt work ... go check all your connections
Old Oct 3, 2005 | 09:07 AM
Relic1's Avatar
connections would be my first guess as well.
Also.... did you pull the needles off?
did you push them around? (the fuel gauge needle slips easily if you force it)
does it move at all when you put in fuel?
I've run my Teg cluster for over 2 years now with no problems.
Old Oct 3, 2005 | 05:08 PM
B A N N E D
Default Re: (Relic1)
connections are good because i check them out already a couple of times. it moves, but just read incorrectly. it would rise up out of nowhere, past full.
JDM_WHR
10
Jun 7, 2010 08:50 AM
tifosi
Jul 11, 2008 10:13 AM
Rxmig7
Feb 24, 2006 04:44 PM
trick_db
May 6, 2005 08:08 AM
Jer'rome
Dec 18, 2004 02:58 AM
