what is a knock sensor do
Old Oct 2, 2005 | 11:33 AM
THC07's Avatar
Default what is a knock sensor do
what is a knock sensor for
Old Oct 2, 2005 | 11:38 AM
coquitlamEG's Avatar
Default Re: what is a knock sensor do (THC1107)
It's like a microphone that's tuned to listen for knocking sounds in your motor. If it hears something it will let your ecu know so it can adjust the timing accordingly to save your engine. If your Knock sensor goes bad or you unplug it, your computer will automaticly pull timing from the engine which cuts back the power quite a bit.
Old Oct 2, 2005 | 11:39 AM
civic_driver's Avatar
detects knock/detonation in the engine... http://auto.howstuffworks.com/ignition-system1.htm
Old Oct 2, 2005 | 01:19 PM
Soccerking3000's Avatar
Default Re: (civic_driver)
the stock knock sensor is worthless, if anything get an aftermarket one that has a readout/screen so you can see the severity of the knock and at what rpm it occurs.
Old Nov 13, 2005 | 01:58 PM
THC07's Avatar
Default Re: what is a knock sensor do (coquitlamEG)
i have a jdm d15b swaped from a usdm d16y8, the y8 harness has a knock sensor but the d15b block dose not have a place for one anawhere on the block. so its just hanging there. is that why my car runs like it weights a few 1,000LBS more.
Old Nov 13, 2005 | 02:00 PM
.Ry's Avatar
.Ry
Yes
Old Nov 13, 2005 | 02:05 PM
THC07's Avatar
Default Re: what is a knock sensor do (turner7205)
do you know if the p28 will solve my problem?
Old Nov 13, 2005 | 02:59 PM
THC07's Avatar
any help. what should I do to solve this problem
Old Nov 13, 2005 | 04:15 PM
.Ry's Avatar
.Ry
I was going to see get the correct ECU for your setup, but I am not good with that area yet. You have to get one that doesnt look for the Knock Sensor, and for me the option was to change over to older OBD system. PM user "Luserkid" on here, he is very good at this.
Old Nov 13, 2005 | 04:23 PM
99blackcivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 &raquo;</TD></TR><TR><TD CLASS="quote">any help. what should I do to solve this problem</TD></TR></TABLE>
a knock sensor can go anywhere on your block or even on a bracket, say the alternator bracket, get creative, hint alternator bracket =P
92'si
Feb 8, 2010 06:27 PM
syntax.
Aug 17, 2005 11:48 AM
rice is nice
Apr 14, 2005 08:46 PM
untitledsn41
Jul 30, 2004 04:48 AM
