b16a2 into 1997 civic cx.
Old Oct 2, 2005 | 11:03 AM
ekx4's Avatar
Default b16a2 into 1997 civic cx.
Ok, just wondering what would be the best way to run the p2t ecu, i have a cx engine harness, si engine harness, and ex engine harness, what is the best way?
is it possible to mod the CX engine harness to work?
i also read somewhere on here, i could just use the EX engine harness, and just wire up the knock sensor, and vtec... but i also read somewhere eles the plugs wont match up for the p2t ecu.
need help quick, gotta get my car bar'd
Old Oct 2, 2005 | 11:20 AM
ekx4's Avatar
Default Re: b16a2 into 1997 civic cx. (ekx4)
bump
Old Oct 2, 2005 | 11:46 AM
Shaun's Avatar
just use your cx harness... get a gsr ecu obd2 p72... and wire or have someone wire up vtec/ knock / IACV , and sell those extra harnesses
edit: whats bar'd?? some sort of emmisions.... what do they look for?
Old Oct 2, 2005 | 12:26 PM
ekx4's Avatar
Default Re: (Shaun)
i dont think i could use the stock gsr ecu, i need to be using the p2t to pass the smog.
Old Oct 2, 2005 | 12:33 PM
Shaun's Avatar
Default Re: (ekx4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekx4 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think i could use the stock gsr ecu, i need to be using the p2t to pass the smog.</TD></TR></TABLE>
oh i see!!! because thats what I did to my dx coupe .. sorry no smog here in south carolina
Old Oct 2, 2005 | 01:39 PM
nighttrain33's Avatar
Default Re: (Shaun)
For my JDM B16, we just used my ex harness and wired the parts you already listed, and I used the P30 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">get a gsr ecu obd2 p72</TD></TR></TABLE>
Just wondering why you would use a GSR ecu instead of the one that is supposed to go with the motor. If you use the GSR ecu, the fuel map will be different and and that ecu will look for secondaries, while the B16 does not have these.
-Shane
Old Oct 2, 2005 | 02:02 PM
Shaun's Avatar
Default Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">
-Shane</TD></TR></TABLE>
for my dx I ran it on my b16a2 no problems... I didnt notice it running rich/lean the secondaries are in the intake manifold... you think secondaries really matter whens a person swaps out there GSR Intake manifold for a skunk2 intake manifold... what will the ecu look for then
Old Oct 2, 2005 | 08:14 PM
Default Re: (Shaun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">for my dx I ran it on my b16a2 no problems... I didnt notice it running rich/lean the secondaries are in the intake manifold... you think secondaries really matter whens a person swaps out there GSR Intake manifold for a skunk2 intake manifold... what will the ecu look for then </TD></TR></TABLE>
Do you have an a/f gauge? The fuel map is quite a bit different on a P72 than on a P2T or a P30. You don't notice a "huge" difference when switching ecu's besides when vtec kicks in, but I definitely like the way the P30 feels in my car.
So, the Skunk2 IM completely gets rid of the secondaries on the GSR? I am pretty sure that it doesn't. The ITR and Civic Si IM's are really similar, but I would be pretty surprised if the Skunk2 IM got rid of the secondaries on the GSR one.
-Shane
Old Oct 2, 2005 | 11:52 PM
ekx4's Avatar
Well, i think im gonna go with the p72 for now, so i can save money to pick up a jumper harness.
unless there is another way to go?
b20beast978
23
Jun 11, 2007 09:52 AM
xJDMCx
Aug 31, 2006 01:26 PM
HondaInteg95
Apr 1, 2006 12:16 PM
nahmanitscool
20
Mar 23, 2005 01:14 PM
hatchboy93
Apr 11, 2003 09:34 PM
