Car Wont Start???
Old Oct 1, 2005 | 11:49 AM
scarface50370's Avatar
Default Car Wont Start???
I just put a y8 head on my d16b ,,,,,,,,,now the car wont start it trys but it wont,,,,,my best bet is the timing i prolly have it fucked up. anyone here know how i can fiz the timing so its good?
Old Oct 1, 2005 | 12:09 PM
Civicse's Avatar
Default Re: Car Wont Start??? (scarface50370)
was everything at TDC when u put the head on? and did u make sure the marks on the cam gear were lined up?
doesnt anyone one how to set a cam gear up tso it starts?
Old Oct 1, 2005 | 12:12 PM
civic_driver's Avatar
the cam has to be at TDC and the crank has to be at TDC... then put tension on the belt and you're good to go
Old Oct 17, 2005 | 08:04 PM
123456civic's Avatar
Default Re: (civic_driver)
If you don't know how to do the timing belt just take it to the shop it will cost about 400 dollars at the honda dealer.
Old Oct 17, 2005 | 08:06 PM
Sliced Beard's Avatar
Default Re: (123456civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 123456civic &raquo;</TD></TR><TR><TD CLASS="quote">If you don't know how to do the timing belt just take it to the shop it will cost about 400 dollars at the honda dealer.</TD></TR></TABLE>
you are full of **** dude.
If I were the tech being asked to set the timing belt timing and that is it I would make an easy hour but that is about it.
The going rate for an hours labor is around 80 to 90 bux or somewhere around that.
1990si
Jul 12, 2006 02:36 PM
90jdmcrxdude
May 17, 2006 09:39 AM
specv5150
11
Oct 7, 2004 02:39 PM
baonest1
Feb 24, 2003 03:37 PM
flyrod
Aug 14, 2002 06:38 PM
