DX to Ex Tranny Swap
Can I get any guidance on doing this? Everything carries over from the DX tranny, right? Do I just slide the whole clutch assembly onto the EX tranny? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">If you dont want to lay in nasty smelly oil that you cant get out of your hair without a 3 hour shower, then drain it. </TD></TR></TABLE>
speaking from experience.
oil is very hard to get out of HAIR. LOL
You don't have to bleed your clutch line, because you don't need to open the system at all. Just take the 2 bolts off that hold the slave cylinder to the transmission, and tuck it away somewhere.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jizzmaster Zero »</TD></TR><TR><TD CLASS="quote">You don't have to bleed your clutch line, because you don't need to open the system at all. Just take the 2 bolts off that hold the slave cylinder to the transmission, and tuck it away somewhere.</TD></TR></TABLE>
exactly. and the clutch bolts to the flywheel the throw out bearing goes on the tranny. its a direct swap. there is no external difference in the trannies.
fake mugen power
15
May 24, 2004 07:17 PM
