Need help with LC-1 wideband hookup
Old Sep 30, 2005 | 07:43 PM
1BlackHatch's Avatar
Default Need help with LC-1 wideband hookup
I want to cut the plug off the end of my stock o2 sensor and wire my LC-1 into it so I can plug and unplug it easier.
Basically I need to find +12VDC, ecu ground or harness ground, and the wire that goes to pin d14 for o2 sensor input.
I have the wiring diagram for the stock sensor. I need to know where to hook the signal wire up to (signal + or - ), if 12vdc is available on the connector, and also if there is a ground wire that runs back to the ecu somewhere readily available in the engine bay.
Thanks in advance.
Da_1991
Nov 10, 2013 07:14 PM
503_EF9
Sep 14, 2008 04:17 PM
accordianex
Feb 19, 2006 07:07 AM
dropd4door
Dec 27, 2004 10:22 PM
JCracer723
Dec 4, 2003 06:15 PM
