wiring wurus .. help
im tryin to figure out an obd0-obd1 wiring harness... i think i have some wires figured out ... but i dont know which 1 is D22... any1?? and are the others correct??
OBD1 plug :
tia
OBD1 plug :
tia
Re: wiring wurus .. help (JCracer723)
Nope... O2 is different. Location D22 is basically a ground, just a ground on the ECU, specifially for the TPS but will work for any other sensor ground.... not needed for the O2.
Re: wiring wurus .. help (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">The green wire is the O2 signal ground wire, thus it CAN be wired up into location D22 (or D21... same ECU ground), but only that wire.</TD></TR></TABLE>
while you are at it.. would u tell me wuts the other white and the 2 black wires from the 02.. tia
EX-T
12
05-24-2008 08:01 PM
