turning T04E into an SC61 by swapping compressor parts?
Old Sep 30, 2005 | 12:03 PM
BlueShadow's Avatar
Default turning T04E into a T3/T61 by swapping compressor parts?
Hey guys,
I've been thinking about buying a new SC6152E or T3/T61 and then selling my Precision T04E 60 trim w/ stg 3 0.63 ar turbine. However Ken from Phoenixturbo gave me an idea in one of his posts.
What all would I have to swap out on the cold side to make it into an SC61 or T3/T61 or other equivalent turbo? is it as simple as swapping out the compressor fan and cover? or is there more to it then that? If I were to get it done by some place like Phoenixturbo, how much would I expect to pay for this kind of conversion? (if they even do them).
Thanks
Modified by BlueShadow at 9:10 AM 10/2/2005
Old Sep 30, 2005 | 12:33 PM
BlueShadow's Avatar
Default Re: turning T04E into a T3/T61 by swapping compressor parts? (BlueShadow)
ok I found some exploded diagrams of a T04B and I'm guessing the following parts would need to be changed.
-compressor backplate & large O-ring
-compressor cover
-compressor fan
-turbine fan/shaft (?)
Now I'm not sure about having to replace the turbine fan/shaft. http://www.turbocharged.com says that the T61 is a big shaft turbo and I believe the T04E has a standard shaft. Does that mean that the bigger T61 compressor fan and cover wont be compatible with the smaller T04E turbine fan/shaft?
EDIT: or are the big shafts only for straight T4 setups, meaning I can use the T04E standard shaft with the T61 cold side?
TIA
Old Oct 1, 2005 | 07:38 AM
BlueShadow's Avatar
bump
EDIT: if I cant upgrade my T04E 60 trim to a T3/T61 what other options do I have? can I convert it something similar to the following: T3/60-1, SC6152E, TS04 cold side, etc.
Modified by BlueShadow at 9:38 AM 10/1/2005
Old Oct 2, 2005 | 07:04 AM
BlueShadow's Avatar
So I was thinking that if I could get a GT3582R compressor housing, compressor fan, and compressor backplate then that pretty much turns my T04E 60 trim into a SC6152E. The only thing different is my turbo has a 270* thrust bearing whereas the SC61 has a 360* thrust bearing standard (I think).
The fan and housing I was looking at is the 56 trim (82mm exducer, 61.4mm inducer) and 0.70 AR housing.
so what do you guys think?
Old Oct 3, 2005 | 08:54 AM
raene's Avatar
You need to balance after swapping wheels... not something I'd want to just "do" myself
jdmb16acivic
Aug 12, 2006 12:04 PM
NotPhilTran
May 2, 2005 06:00 PM
4U2NV
Dec 29, 2002 11:06 AM
ludelvr
Sep 16, 2002 08:10 PM
