CEL 14 codes found!
Old Sep 29, 2005 | 11:30 PM
SOHCex20's Avatar
Default CEL 14 codes found!
Throwing 14 codes on my 99 ex. Car runs fine up until it hits closed loop and then everything goes nuts. There are quite a few manufacture specific codes for Baro sensor, and random misfire, but i've had those for a long time from being boosted, anyways, had a code for high circuit voltage for both O2 sensors, high voltage for ECT sensor, IAT sensor, MAP sensor, and IACV sensor.
Could my ECU be crap?? I checked all the wiring around the intake manifold, and the wires that would follow the harness for all of those sensors. Just weird that these are the sensors that are used in giving the ECU readings for A/F ratio. My car leans out like crazy when this is going on and can't even drive it normally because it bogs down like no other. NEED HELP FAST.
Old Sep 30, 2005 | 05:16 AM
SOHCex20's Avatar
Default Re: CEL 14 codes found! (SOHCex20)
bump. Anyone????
Old Sep 30, 2005 | 07:31 AM
SOHCex20's Avatar
NEED HELP! Still can't figure it out.
Old Sep 30, 2005 | 08:02 AM
Project_DX's Avatar
i'm no expert, but for your car to trow all thoughs codes.....for all thoughs sensors....at the same time, it would have to be the one thing that they are all connected to, i would go to autozone, they check codes for free, and see what they say
good luck with this one
Old Sep 30, 2005 | 10:20 AM
SOHCex20's Avatar
Default Re: CEL 14 codes found! (Project_DX)
Well, I plugged my friends ECU from his 99 civic ex to see how it runs, ran fine until I turned it off at Wendy's for lunch, and then on the way back, started running like **** again, so I don't even think its the ECU now. I have a scanner of my own for OBD2 so I can check the codes. I can't imagine a wiring problem throwing all of these codes at the same time and having my Air Fuel ratio lean out to about 20 to 1 at idle and doesn't let me accelerate at all, no power.
Connectors have no corrosion in them either, as well as the grounds. Could my SAFC be the problem?? I don't know how, but all my solders are good, nothign broken, ran fine until I welded a hole in my exhaust. SO damn weird.
Old Sep 30, 2005 | 10:41 AM
SOHCex20's Avatar
Also, I was just told that because I welded it on the car, I could have sent crazy electricity through the car fryign stuff. Would I have to replace all those sensors that I threw codes for, or would there be a fuse I could have popped or relay of some sort???
Old Sep 30, 2005 | 11:28 AM
Project_DX's Avatar
that could be the case, when you were welding your exhaust did you disconnect your bat. if not you deff. could have fried some ****!!
i have a friend that has his own shop so i get to use all his **** to work on my car, i when to weld my exhaust about 3 mounths ago, right before i started he came running across the place yelling at me to see if i had disconnected my batt. i hadn't...i don't know what would have happend if i had let it go...all i know is every time i weld anything anymore i dis the batt
Old Sep 30, 2005 | 11:37 AM
Project_DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCex20 &raquo;</TD></TR><TR><TD CLASS="quote">Also, I was just told that because I welded it on the car, I could have sent crazy electricity through the car fryign stuff. Would I have to replace all those sensors that I threw codes for, or would there be a fuse I could have popped or relay of some sort???</TD></TR></TABLE>
you could check all the fuses, but <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCex20 &raquo;</TD></TR><TR><TD CLASS="quote"> had a code for high circuit voltage for both O2 sensors, high voltage for ECT sensor, IAT sensor, MAP sensor, and IACV sensor.
</TD></TR></TABLE>from what this sounds like you might have fried your sensors
Old Sep 30, 2005 | 11:45 AM
turboxsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project_DX &raquo;</TD></TR><TR><TD CLASS="quote">that could be the case, when you were welding your exhaust did you disconnect your bat. if not you deff. could have fried some ****!!
This what i was going to say!! Did you disconnect the battery?
Old Sep 30, 2005 | 12:05 PM
SOHCex20's Avatar
Default Re: CEL 14 codes found! (turboxsi)
no i didn't I dont' know what I was thinking. I'm going to check all the sensors in a little bit to see if they work or have any resistance. If you could find out, how much damage could I have done, i mean the worst possible scenario. That way I knwo what to expect and hope it only gets better from there.
Old Sep 30, 2005 | 12:31 PM
Project_DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCex20 &raquo;</TD></TR><TR><TD CLASS="quote">no i didn't I dont' know what I was thinking. I'm going to check all the sensors in a little bit to see if they work or have any resistance. If you could find out, how much damage could I have done, i mean the worst possible scenario. That way I knwo what to expect and hope it only gets better from there.</TD></TR></TABLE>
i'm stopping by my friends shop later i'll ask him worst case scenario and post back up after work
Old Sep 30, 2005 | 01:06 PM
SOHCex20's Avatar
Thanks man, I really appreciate it. I need to figure out what needs to be replaced and what can stay. I hope its jsut the ECU and not the sensors itself.
Old Oct 1, 2005 | 10:37 AM
Project_DX's Avatar
he wasn't there , but i did ask my other friends dad who tows on the side and he said that you deff. could have fried all of the sensors even the ECU. i'm going over to my friends house who owns the shop later tonight so i'll get a strait answer
Old Oct 1, 2005 | 11:06 AM
SOHCex20's Avatar
hey man, i just recently narrowed it down to the ECT sensor itself. The car honsetly runs better than it did ever. Smooth idle, better overall performance. I called a performance shop that deals w/ hondas/acuras and they said ECT sensors can effect these cars performances because they are quite critical to the A/F ratio. Now I'm throwing NO codes at all, and it runs and pulls very hard again. Thanks for all the posts. I'll make sure not to make this mistake again.
Old Oct 1, 2005 | 09:02 PM
Project_DX's Avatar
^^good to hear
sorry i couldn't help much
Old Oct 2, 2005 | 12:36 AM
SOHCex20's Avatar
thanks though. you guys got me going in the right direction. It would have probably taken me quite a bit longer, because I would have bought an ECU, then checked the sensors, but probably wouldn't have the time to even check them because who knows what direction I would be going in. Thanks again.
luispequeno
Dec 13, 2010 09:16 AM
lmike6453
Oct 29, 2009 06:02 PM
sohctodohc
12
Nov 9, 2007 12:37 PM
hair_rice
Apr 23, 2004 11:19 AM
Leisyman
May 6, 2003 09:35 AM
