Anyone ever had a Rotary type (99-00 D16y7, 3 wire) IACV go bad on them?
Old Sep 29, 2005 | 02:17 PM
hondaguyef's Avatar
Default Anyone ever had a Rotary type (99-00 D16y7, 3 wire) IACV go bad on them?
EDIT:I NEED one of these ASAP! Either just the sensor itself or I'll buy the whole D16y7 TB. LMK. Thanks.
I have a 99' Sedan w/ the stock D16y7 in it. It has a y8 mani w/ the linear type IACV port blocked off so, that (like it came from the factory) it may utilize the 3 wire Rotary type IACV. The ECU is throwing a p0505 code (IAC malfunction) and it has a surging idle causing it to fail inspection. I've checked thew wiring, cleaned the valve as good as I can and even checked the ECU plug to make sure someone didn't attempt the 2 wire swap unsucessfully. If anyone has had one of these fail please let me know as I am stumped. Thanks
Phil
Modified by hondaguyef at 9:01 AM 10/2/2005
Old Sep 30, 2005 | 02:12 AM
hondaguyef's Avatar
Default Re: Anyone ever had a Rotary type (99-00 D16y7, 3 wire) IACV go bad on them? (hondaguyef)
Anyone?
Old Sep 30, 2005 | 06:18 AM
sicones's Avatar
Default Re: Anyone ever had a Rotary type (hondaguyef)
I would check the wiring again get a mulitmeter (DMM), and then try another throttle body, if you still cant find it swap to manual and do the 2 wire valve
Old Sep 30, 2005 | 11:17 AM
hondaguyef's Avatar
Default Re: Anyone ever had a Rotary type (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">I would check the wiring again get a mulitmeter (DMM), and then try another throttle body, if you still cant find it swap to manual and do the 2 wire valve </TD></TR></TABLE>
Yeah, the wiring has been checked(a few times) in different areas to ensure good connection. I am in the process of finding a D16y7 TB w/ the 3 wire IACV on it to test but, if that doesn't work. I'll have to switch to the 2 wire. Only prob is I'll have to do a complete y8 head swap and use the Y8 ecu(cause the y7 ECU doesn't support the 2 wire IACV) which I'm trying to steer clear of having to do.
Phil
Old Sep 30, 2005 | 05:07 PM
sicones's Avatar
is your car auto or manual??
Old Sep 30, 2005 | 05:26 PM
Mista Bone's Avatar
D Tranny Guru
clean, and clean again. Took me almost a hour to free up the IACV on a buddys DX......
Old Oct 1, 2005 | 05:28 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">is your car auto or manual??</TD></TR></TABLE>
Manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">clean, and clean again. Took me almost a hour to free up the IACV on a buddys DX......</TD></TR></TABLE>
I noticed after I cleaned it (I've only cleaned it once) that it did oscilate much easier. What did you use to clean it?
Phil
Old Oct 2, 2005 | 05:02 AM
hondaguyef's Avatar
I need to buy one of these asap. If you have it PM me w/ a price. Thanks.
Phil
santii7
Jun 21, 2011 07:22 AM
cbaber
Aug 17, 2009 04:00 PM
hondaguyef
Oct 2, 2005 05:04 AM
Catman316
11
Dec 21, 2004 08:37 AM
IDriveHonda
Apr 18, 2003 06:37 AM
