iacv 3-2 wire problem HELP!
hello my fellow ht ppl, i have a 97 lx and just did a y8 swap. im using a 99 y8 with obd2a harness and p2E ecu (non vtec). i did the 3-2 wire conversion cut the orange wire and move the black/blue wire from a14 to a12. so i started it up and right away i got code 14 (iacv) and jumps at idle up and down but most of the time it idles fine but still get the code. any ideas how to make this code disappear?!!?!?!
is it cus im using p2E ecu???
thanx in advance!!
thanx in advance!!
Re: iacv 3-2 wire problem HELP!
just put in a y7 throttle body with the 3 wire plug and converted the harness back to 3 wire -____-.
my problem now is that it jumps up and down at idle. code is gone, still running p2e
some intake manis come with a 2 wire plug for the iacv thats bolted to the intake mani and others come with 3 wire plug iacv located at the bottom of the throttlebody. i tried to avoid having 2 iacv with only one being plugged but my ecu thinks otherwise lol
Chaosgrunt
03-13-2019 06:23 PM
fishnfst
11
11-22-2004 08:09 PM
