D-series power steering on LS B18B
Old Sep 29, 2005 | 07:09 AM
racer_X_123's Avatar
Default D-series power steering on LS B18B
Like the title says, i have a Y7 and i am going to do an LS swap, can i resuse my power steering pump and all that or will it not match up? Also, is it becasue the bracket will not line up becasue i can fab a bracket if that is the case.
Old Sep 29, 2005 | 10:24 AM
RiceNmotioN's Avatar
Default Re: D-series power steering on LS B18B (racer_X_123)
You can get it to work. I had mine on my 99 LS swapped Civic EX. It it a real close fit but should line up almost the same. I used an LS P/S belt. You have to put it at full tight, but it will still slip a bit. Also the P/S line is a bit shorter than the one on the 99 SI's so it'll be a tight fit. Honestly, it would fit better to use a B-series pump and SI line, but will work.
Old Sep 29, 2005 | 10:27 AM
Default Re: D-series power steering on LS B18B (RiceNmotioN)
cool thanks for the info
EJ8_Man
May 8, 2011 10:31 PM
Tong.Y
Apr 17, 2011 12:06 PM
cbaber
May 28, 2009 09:43 AM
ohsnapzafingcu
Dec 8, 2008 07:22 AM
UncleBen'sRacing
Mar 30, 2003 01:31 AM
