H22 HEADGASKET
Old Sep 28, 2005 | 10:11 PM
nitroeg's Avatar
Default H22 HEADGASKET
my headgasket blew on my h22 ek coupe has anyone done a head gasket on this car with a h22 swap with out taking the motor out it seems almost impossible to take the timing cover off its very close to the strut tower anyways since im taking it apart what kind of build do you guys recommend im looking to do 75shot of nitrous
Old Sep 28, 2005 | 10:24 PM
Luserkid's Avatar
Default Re: H22 HEADGASKET (nitroeg)
A 75 shot is fine on a stock motor. And good luck with the headgasket. Its going to be beyond a bitch in there. If you have an auto tensioner you shouldnt even try it without pulling the motor.
Old Sep 28, 2005 | 10:26 PM
SOHC4life 96's Avatar
Default Re: H22 HEADGASKET (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">If you have an auto tensioner you shouldnt even try it without pulling the motor. </TD></TR></TABLE>
Yeah, we had a hard enough time with it OUT of the car.....
Old Sep 29, 2005 | 02:18 AM
JDM_sedan's Avatar
you blew a headgasket and now your building the motor for nitrous.......... just cause you cant reach the timing belt cover?
[post edited]
Old Sep 29, 2005 | 06:21 AM
nitroeg's Avatar
Default Re: H22 HEADGASKET (JDM_sedan)
i dont understand your answer what do you mean
Old Sep 29, 2005 | 07:18 AM
IHateJDM's Avatar
you can get the timing cover off. it'll just take a few min to find the correct angle to pull it out at. If you have the auto tensioner, now would be a great time to do the manual conversion. You will not need to pull the motor for the headgasket (although it is a bitch to do). You can run a 75 shot on a 100% stock H without problems, just add fuel or retard timing to prevent detonation and you'll be fine.
Old Sep 29, 2005 | 07:32 AM
EGmikeH22's Avatar
* B A N N E D *
I have done a head on my H22 hatch, TWICE!
It is a bitch, the most PITA part is the lower timing cover, but it will come off.
Good LUCK
Old Sep 29, 2005 | 09:28 AM
nitroeg's Avatar
thanks guys
JDMRice
Oct 9, 2007 08:25 PM
H22INTEGRAGIRL
Mar 7, 2006 08:59 PM
LDS
Sep 13, 2005 01:36 PM
mini-cRx
Mar 9, 2004 07:16 PM
