redline?
i got a 92 integra with a b16 but the damn thing redlines at 7500, and i think thats pretty messed up since my friends civic redlines at 82 and hes got a b16 wiuth cold air intake so i duno if i needa reset my ecu or wut i need sum help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLEO245 »</TD></TR><TR><TD CLASS="quote">what ECU are you using?</TD></TR></TABLE>
^^thats a factor
^^thats a factor
sounds like you have an automatic ECU or something weird like that. i swapped my 240 using an automatic engine and harness commanded by a manual ECU and harnessed by a manual transmission. saved some money only to spend more time sorting through wires and problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R34lude »</TD></TR><TR><TD CLASS="quote">Know the limit of your car before you and mes up something.</TD></TR></TABLE>
correct. changing your redline is not something that should be taken lightly. perhaps the ECU is restricting redline for some other reason. i've heard of similar problems with GSR's so maybe you should do some diagnostics before you go an try to tell the ECU what is best for the engine.
