redline?
Old Sep 28, 2005 | 05:39 AM
redb16integra's Avatar
Default redline?
i got a 92 integra with a b16 but the damn thing redlines at 7500, and i think thats pretty messed up since my friends civic redlines at 82 and hes got a b16 wiuth cold air intake so i duno if i needa reset my ecu or wut i need sum help
Old Sep 28, 2005 | 06:19 AM
LL2009's Avatar
Default Re: redline? (redb16integra)
what ECU are you using?
Old Sep 28, 2005 | 06:57 AM
ecks_fourttwo's Avatar
Default Re: redline? (LLEO245)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLEO245 &raquo;</TD></TR><TR><TD CLASS="quote">what ECU are you using?</TD></TR></TABLE>
^^thats a factor
Old Sep 28, 2005 | 08:59 AM
95lstegman's Avatar
Default Re: redline? (ecks_fourttwo)
sounds like you have an automatic ECU or something weird like that. i swapped my 240 using an automatic engine and harness commanded by a manual ECU and harnessed by a manual transmission. saved some money only to spend more time sorting through wires and problems.
Old Sep 28, 2005 | 09:56 AM
xplanetearth420x's Avatar
Default Re: redline? (95lstegman)
it has nothing to do with ur motor and u friend with the same motor and having a intake,go out have someone chip ur ecu and u can redline at what ever u want
Old Sep 28, 2005 | 01:08 PM
Ichigo's Avatar
Know the limit of your car before you go and mess up something.
Modified by R34lude at 4:09 PM 9/29/2005
Old Sep 28, 2005 | 02:17 PM
95lstegman's Avatar
Default Re: (R34lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R34lude &raquo;</TD></TR><TR><TD CLASS="quote">Know the limit of your car before you and mes up something.</TD></TR></TABLE>
correct. changing your redline is not something that should be taken lightly. perhaps the ECU is restricting redline for some other reason. i've heard of similar problems with GSR's so maybe you should do some diagnostics before you go an try to tell the ECU what is best for the engine.
Old Sep 28, 2005 | 04:28 PM
adseguy's Avatar
Default Re: (95lstegman)
unless you had an ECU change I would say your Tach is off, which is VERY normal. You are probably hitting fuel cut which is bad if you do this a lot
Old Sep 29, 2005 | 04:37 AM
95lstegman's Avatar
Default Re: (adseguy)
yeah, but the tach always reads high, not low. at least i've never seen one read low. every car i've been in reads high.
ramonjones16
Jul 27, 2009 12:13 AM
purple98ek
10
Jun 5, 2007 12:01 AM
eg6madness
Jan 27, 2007 09:02 AM
LBR92DA-T
Dec 7, 2003 06:30 PM
Hybridize
Oct 19, 2003 05:10 PM
