boo boo
so i made a boo boo. i don't know if i jacked up my car or not but a quick question. how much harm can a 50mph second gear drop hit rev limitor a couple times before i even realize it do to a motor.
the thing is.. on my car, when i got it i think it has a gsr rev limitor. the redline is 7,500 rpm's. which i don't think is ls normal redline.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheBangZ »</TD></TR><TR><TD CLASS="quote">the thing is.. on my car, when i got it i think it has a gsr rev limitor. the redline is 7,500 rpm's. which i don't think is ls normal redline.</TD></TR></TABLE>
your tach could be off just like alot of the other hondas.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">
your tach could be off just like alot of the other hondas.</TD></TR></TABLE>
OK, I think he figured it out that he does have a LS tach not GSR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMoMo »</TD></TR><TR><TD CLASS="quote">
don't worry man, LS is 7500 and GSR is 8200 so you have the right stuff in ur car. You will be fine. I think 2nd gear can go upto 70 on 2nd gear......</TD></TR></TABLE>
LS is more like 7000 Rpm Redline
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheBangZ »</TD></TR><TR><TD CLASS="quote">my ls teg. i tryed racing a stang when his gf looked at me and smiled..... i got... yeahZ. distracted.</TD></TR></TABLE>
You're a ******* moron. Stop living now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SingeBgd »</TD></TR><TR><TD CLASS="quote">
LS is more like 7000 Rpm Redline</TD></TR></TABLE>
the fuel cut outs like 7200 and the redline on most is 6800
the fuel cut outs like 7200 and the redline on most is 6800</TD></TR></TABLE>
^^This is correct
I wasnt sure where execly the redline was but i knew it wasnt at 7500
^^This is correct
^^This is correct
I wasnt sure where execly the redline was but i knew it wasnt at 7500</TD></TR></TABLE>
id blame that off on the tach being off, unless hes got a chiped ecu
^^This is correct
whoa. this is pretty scary. people need to read this: The rev limiter will <U>NOT</U> protect your engine from over revving if you accidently downshift when you arent supposed to. It will cut fuel, but it will not prevent the motor from over revving.
However, if your car still runs, and you dont hear any terrible noises, it is probably fine.
yes you can still mechanically overrev your engine past the factory fuel cut if you shift to to low of a gear at at a certain speed. my freind just destroyed his type r this way going from 5th to 2nd at like 85 or so, man you shouldve seen that motor when we pulled it apart, it mustve turned like 15000 rpms!!
<FONT COLOR="red">READ THIS FOR THE TRUTH ON ALL OF THIS...too much **** floating around</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h4x »</TD></TR><TR><TD CLASS="quote">Uhh the redline doesnt start until 7200, where the fuel cutoff is.</TD></TR></TABLE>
Incorrect Redline is 6800...shifting past that point will only make you go slower since you are out of the peak powerband
7200 fuel cut does exactly that. It cuts fuel at 7200, so If you downshift and don't give it gas you will OVER REV. meaning going 100mph without the foot on the gas pedal and put it into second and drop the clutch the car WILL rev past 7200 because your foot is not on the gas.
At 50mph you can shift to 2nd safely on an LS...if youfelt the fuel cut you are fine since it is there to save you from overrev by means of not shifting earlier.
This clears everything. Bump this post if you agree.....if you don't......go read up and then bump this post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote"><FONT COLOR="red">READ THIS FOR THE TRUTH ON ALL OF THIS...too much **** floating around</FONT>
i thought i had it right.
</TD></TR></TABLE>i thought i had it right.
Bump
</TD></TR></TABLE>Bump
