NEED HELP ON TURBO SETUP!!!!!
Old Sep 27, 2005 | 04:41 PM
EG5_Si's Avatar
Default NEED HELP ON TURBO SETUP!!!!!
well i just got done putting on my custom turbo kit on my B20B block and LS head....the kit includes.....b-series manifold, small Garrett T3 A/R 42 trim with internal wastegate (i think its from a saab car) with a small front mount intercooler, pipings, Greddy Type S BOV, oil feed and oil line tap to the oil pan and a custom 3inch down pipe....... I don't have any upgraded fuel management now....I'm planning to get my ECU chipped this friday....but i do have those ghetto Check Valves taht connects to the MAP sensor that my homeboy made for me so i can drive the car...but my car is FUking blowing white smoke like crazy dude.....plus there's no boost it fuking laggs when I rev pass 4000 rpm on 1st gear then on 2nd,3rd,4th,5th I can't even go pass 3000rpm...you can hear the turbo spooling but the car just wants to stop...its like chocking dude..plus the white smoke......i'm thinking that my valves are gone or at least some of them or a blow head gasket...i dunno..does anyone know???? i need help...thanks
Old Sep 27, 2005 | 04:42 PM
G2 Speed's Avatar
Default Re: NEED HELP ON TURBO SETUP!!!!! (EG5_Si)
please tell me.... you aren't driving the car untuned...
Old Sep 27, 2005 | 04:44 PM
Luserkid's Avatar
Oh dont worry his not boosting from the sounds of it.
You guys need to take it to an actual shop and have it installed correctly. You dont know what the **** your doing.
Old Sep 27, 2005 | 04:45 PM
EG5_Si's Avatar
Default Re: NEED HELP ON TURBO SETUP!!!!! (G2 Speed)
I just took it for a spin around the block but didn't rev pass 4000 rpm
EG5_Si's Avatar
just wanted to hear the BOV
Old Sep 27, 2005 | 04:47 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG5_Si &raquo;</TD></TR><TR><TD CLASS="quote">just wanted to hear the BOV </TD></TR></TABLE>
x10000 with x 100000000000000000000
Old Sep 27, 2005 | 04:48 PM
G2 Speed's Avatar
Default Re: NEED HELP ON TURBO SETUP!!!!! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote"> x10000 with x 100000000000000000000</TD></TR></TABLE>
turbo OWNZ you!
Old Sep 27, 2005 | 04:49 PM
EG5_Si's Avatar
so what ....its just not tune...is that what you're saying?
Old Sep 27, 2005 | 04:54 PM
EG5_Si's Avatar
everything seems right....all the oil lines, vacum lines, pipings....i checked the rubber claps there's no leakage but the downpipe is leaking a little bit....you can hear the BOV if i drive it.....oh yeah no Boost guage........i know......anyways i need help not **** from yall......i need some advice man...any will be helpful...
Old Sep 27, 2005 | 04:55 PM
Luserkid's Avatar
Tuning is the least of your problems right now. You cant even tune with how it is. The install is where the problems at.
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG5_Si &raquo;</TD></TR><TR><TD CLASS="quote">everything seems right....all the oil lines, vacum lines, pipings....i checked the rubber claps there's no leakage but the downpipe is leaking a little bit....you can hear the BOV if i drive it.....oh yeah no Boost guage........i know......anyways i need help not **** from yall......i need some advice man...any will be helpful... </TD></TR></TABLE>
/thread.
Old Sep 27, 2005 | 04:59 PM
EG5_Si's Avatar
so what should i do...
Old Sep 27, 2005 | 05:01 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">You guys need to take it to an actual shop and have it installed correctly. You dont know what the **** your doing. </TD></TR></TABLE>
Old Sep 27, 2005 | 06:23 PM
G2 Speed's Avatar
that pretty much sums it up for you lol
Old Sep 27, 2005 | 06:52 PM
Vintech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote"> turbo OWNZ you! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Oh dont worry his not boosting from the sounds of it.
I agree with you two, But lets at least try to help him!
1. First try posting in forced induction
2. Honda-Tech Team ASSEMBLE
3. Just kidding #2 never works, see #1
Modified by Vintech at 8:01 PM 9/29/2005
Old Sep 27, 2005 | 07:21 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG5_Si &raquo;</TD></TR><TR><TD CLASS="quote">well i just got done putting on my custom turbo kit on my B20B block and LS head....the kit includes.....b-series manifold, small Garrett T3 A/R 42 trim with internal wastegate (i think its from a saab car) with a small front mount intercooler, pipings, Greddy Type S BOV, oil feed and oil line tap to the oil pan and a custom 3inch down pipe....... I don't have any upgraded fuel management now....I'm planning to get my ECU chipped this friday....but i do have those ghetto Check Valves taht connects to the MAP sensor that my homeboy made for me so i can drive the car...but my car is FUking blowing white smoke like crazy dude.....plus there's no boost it fuking laggs when I rev pass 4000 rpm on 1st gear then on 2nd,3rd,4th,5th I can't even go pass 3000rpm...you can hear the turbo spooling but the car just wants to stop...its like chocking dude..plus the white smoke......i'm thinking that my valves are gone or at least some of them or a blow head gasket...i dunno..does anyone know???? i need help...thanks</TD></TR></TABLE>
gsrswap
Aug 1, 2008 05:15 PM
88superrex
May 4, 2005 06:50 AM
OG SHG_EM1
Mar 28, 2004 09:10 PM
napester21
Aug 20, 2003 10:18 PM
