Rebuilt my turbo and it still smokes!!!
Old Sep 27, 2005 | 01:09 PM
Burke's Avatar
Banned
Default Rebuilt my turbo and it still smokes!!!
I just rebuilt my garret (well AIResearch) turbo with a kit from the g-pop shop on ebay and it still smokes. i mean there was a BUNCH of burnt up oil in my turbine, so i figured it would go away after the rest burnt off, but it still smokes the SAME way it did before, but now more under load and but about the same at idle, etc
any suggestions?
thanks
burke
Old Sep 27, 2005 | 01:17 PM
electric_rex's Avatar
Default Re: Rebuilt my turbo and it still smokes!!! (Burke)
it might be bad rings did you check to see if you were smoking when you took the turbo off. i had the same problem and it ended up being my rings bc i was smoking when i started the car without the turbo on . by the way i fabbed a exhaust pipe to replace the turbo and go from the turbo manifold straight to the exhaust.
Old Sep 27, 2005 | 02:29 PM
redzcstandardhatch's Avatar
something different
i had the same problem...turned out i had 2 causes...niether was turbo's fault
1) WAY too high of oil pressure and volume at turbo. get a restrictor. people use nitrous jets, some random autometer fitting, or ballvalves.... (stealthmode sells the ballvalve thing)
2) this was the kicker...my pcv system wasnt doing ****. almost clogged..and under boost it wasnt venting a bit. positive crankcase pressure meant positive turbo center section pressure to (through return line), and it was pissing oil out the seals due to that.
it wasnt burning oil, it was boiling it, resulting in a minimal oil loss, and MAXIMUM oil smoke (much more smoke boiling than burning. )
good luck figureing this out!
Old Sep 27, 2005 | 03:40 PM
nonvtecD's Avatar
Get a restrictor, do a compression test.
Old Sep 27, 2005 | 10:04 PM
CRXdan's Avatar
do a leakdown test and if it smokes under idle it coudl be valve seals/guides. does it always smoke on idle or only after a hard run?
Old Sep 28, 2005 | 12:50 PM
boost'dsiR's Avatar
Default Re: (CRXdan)
im looking for the same answer
Old Sep 28, 2005 | 01:26 PM
mstolars's Avatar
Default Re: (boost'dsiR)
I'm having pretty much the same problems on my boosted GSR, smokes pretty random though. Only smokes at idle though, but sometimes it won't smoke all day then all of a sudden it'll start smoking. I pulled the charge piping from the turbo and it's not wet, downpipe looks clean too. After a week or so of the random smoke, I'm starting to smell burning oil after a full boost run when it goes back into vacuum on the gauge. I don't have a restrictor, but will probably get one to see if it will help, what kind of pressure do you set the restrictor at to get good flow to the turbo.
Old Sep 28, 2005 | 02:05 PM
boost'dsiR's Avatar
Default Re: (mstolars)
yea
i got as little reducer . but no luck . still smoke ALITTLE BUT MY OIL IS FINE . imma try to run the whole line in a smaller size
Old Sep 28, 2005 | 04:13 PM
TheShodan's Avatar
Moderator
Default Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">Get a restrictor, do a compression test.</TD></TR></TABLE>
Check the oil pressure AT THE LINE, before you do that restrictor. You may Fry it trying to prevent something. You starve it, you've killed it.
Old Sep 28, 2005 | 07:24 PM
Burke's Avatar
Banned
Default Re: (TheShodan)
im gonna probably go with a restrctor. anybody know a good place that sells them, i think atp does buts its like $14 for a lil hunk of brass.
compression is real good, 190 180 185 185, and its not the valve seal either, i know how they act. i know for a fact that its turbo because i pulled/scraped coked up oil out of the hot side where there is that round cup shaped thing. it was FULL of ****! i have pretty crazy oil pressure and like a -4 an line i think. so i think i may be drowing it out.
thanks for all the help guys!
Old Sep 29, 2005 | 09:46 AM
boost'dsiR's Avatar
Default Re: (Burke)
people say its my rings but i did a leak down and everything was good . brand new valve seals . on my turbo u caNsee oil on the hot side its not on the charge pipe but i noe for a fact its in the housing.is 40 to 45 oil pressure at idle to much for the turbo?
Old Sep 30, 2005 | 10:36 PM
CRXdan's Avatar
Just get an air restrictor valve from your local hardware store. Its basically the same thing stealthmode perofmrance sells. its about 5-10 bucks.
Old Sep 30, 2005 | 10:39 PM
CRXdan's Avatar
Oh and an update on my smoking situation, I took apart my turbo and replaced th ehot side seal with a used one i had laying around, put on an oil restrictor, probably smokes about 80% less but still puffs a bit of blue, but still nothing liek before. I think its time for a full turbo rebuild running without a restrictor just killed it there was TONS of coked material where the exhaust turbine seal sits. Go figure, at 70-80 psi pressure I dont see why not. Oh, and a turbo is meant to see about 25psi MAX&gt;
Old Oct 1, 2005 | 02:00 AM
mrx's Avatar
mrx
Want to know too.
Old Oct 1, 2005 | 04:39 AM
DelSolMike's Avatar
Is there oil in you're intercooler piping or downpipe? Check your oil return line and make sure its not kinked and backing up oil under boost.
Old Oct 1, 2005 | 09:11 PM
boost'dsiR's Avatar
Default Re: (DelSolMike)
ican get that restrictor at a local hardware store?
Old Oct 2, 2005 | 01:32 AM
CRXdan's Avatar
anywhere they sell air compressor accesories.
nihad
Nov 30, 2008 06:40 PM
GEN2 LS
Jul 3, 2008 04:59 AM
luv2boost
Jul 6, 2007 05:01 AM
Rob!
Dec 18, 2004 03:08 PM
donpeters
Dec 6, 2004 08:21 AM
