BB-MS question
First off, I searched, I couldn't find aswers.
I basically have a '00 SI brake setup on my EG.
It works fine but I'd like the better modulation that the 1" gives you. (I got to drive a coupe with a 1" MS and loved it)
So the question is, do I need to switch brake boosters or will a 1" bolt up to the '00 SI BB?
and what did the 1" come in?
I know that the ITR came with it, but I've seen GSRs with 1" also... I'm not sure if they're upgraded or not.
Modified by Relic1 at 2:39 PM 9/27/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">
re-flaring on the other hand is another story.
yep, i ran into that after I had already removed my old bb/mc. had to put the old crap back in, still haven't dealt with the lines yet, but i guess I'll have to sooner or later.
</TD></TR></TABLE>yep, i ran into that after I had already removed my old bb/mc. had to put the old crap back in, still haven't dealt with the lines yet, but i guess I'll have to sooner or later.
ok, since you've done it, how difficult is reflaring the line?
what tool/parts would I need?
I'd still like to go with a 1" but the reflaring aspect worries me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">ok, since you've done it, how difficult is reflaring the line?
I'd still like to go with a 1" but the reflaring aspect worries me.</TD></TR></TABLE>
I had been corrected yesterday, you only need to reflare if its an abs MC. If non-abs, you'll be fine. Also, reflaring is not hard, you just need a special tool to do it.
I did some searching through yards and ebay and the abs model can be had, but the non-ABS model is out of stock everywhere.
So if I really want this, I have to flare one of the line.
I've read a few write ups and it doesn't look that bad. ~$40 worth of tools and I should be good to go.
Hopefully the local Autozone has the flare nut I need.
Now all I need to figure out is what brake fluid to use.
WhiteNess
Oct 25, 2006 09:03 PM
DaveSi677
Jul 28, 2006 08:56 AM
fowler!
26
May 29, 2002 03:32 PM
