Transmission Question 00 Si
Re: Transmission Question 00 Si (schlit)
i would also like to know..i have a 2000 Si with 47K on it and it does the same thing..its not horrible or anything but sometimes theres a slight grind going into second..
adaM
adaM
If u race it it's probably the synchros. 2nd and 3rd gear like to go out. I lost my 3rd gear on my other tranny. It's only going to slightly grind at first (at high RPMs). But later when it gets worse, it'll grind at lower RPMs. U might also want to check the tranny oil first before jumping to conclusions. If the oil is low, it will cause it to grind or pop out of gear.
Re: Transmission Question 00 Si (t0p_sh0tta)
My transmission blew up around 20,000mi for the same reason. There should be a service bulletin for this so they shouldn't give you as much hell as they did me when the problem was first surfacing. Stay diligent and threaten to take it higher up the ladder if they don't take care of you (if it is in fact still under warranty).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">It has nothing to do with racing. Change the tranny fluid and use ONLY honda MTF. See if that works.</TD></TR></TABLE>
? How can you be sure? Driving habits have a ton to do with synchro life. If you race the hell out of it all the time, then most likely you are going to ruin a synchro.
3rd gear synchros are notorious for going out in almost all Honda's that are raced. Mine in my SI are starting to grind and all my friends have gone through at least one set in their Civics.
Re: (ek4 fa sho)
mine doesn't grind but a friend of mine has a 00 si and he said they had a factory recall on the 00 si's cuz of 5th grinding
dunno about 2nd or 3rd
most honda's i hear about loose 3rd
Mr. Badwrench
Re: (ebp 99 si)
honda guys are going through what we did with the mustangs and camaro's in the early 90's. syncro's are very soft metal. they go bad. it is innevitable. unless you go with a clutchless tranny but thats not possible in a street driven car.
Re: (TwistedSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedSI »</TD></TR><TR><TD CLASS="quote">3rd gear synchros are notorious for going out in almost all Honda's that are raced. Mine in my SI are starting to grind and all my friends have gone through at least one set in their Civics.</TD></TR></TABLE> yep, my 3rd gear gets stuck at times, i get the feel that the 3rd gear is going to be the first to go pretty soon.
Re: (ek4 fa sho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4 fa sho »</TD></TR><TR><TD CLASS="quote">how much does it cost to get a synchro replace? i'm grinding 2nd to 3th in high rpmz</TD></TR></TABLE>
id like to know this also..
adaM
adaM
Re: si tranny
u guys r kinda making me worry bout this now..i got 00si wit 40K on it and i haven't had anything now im paranoid i will be driving along and its gonna blow!! err i shoulda read this
jus f0 dekarayshunZ
Re: si tranny (sir2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir2k »</TD></TR><TR><TD CLASS="quote">double clutch helps the grinding</TD></TR></TABLE>uh wtf are yout alking about.....if your under warranty you should be ok....i got mine replaced once and im due again i got about 52k on my tranny right now.....there was a service bulletin on si trannies for the civic si
