Squeaky Cltuch+GREASY ASS TRANNY?!?!?!?!?!
Old Sep 26, 2005 | 10:04 PM
bonta-kun's Avatar
Default Squeaky Cltuch+GREASY *** TRANNY?!?!?!?!?!
well i searched and most said that with a squeaky clutch its most likely caused by the slave cylinder being dry and needing grease
so i check the slave cylinder and my tranny is covered in build up and grease all over my tranny?
is this mean i need a new slave?
ill have more pics tommorw morning when the sun comes up
Old Sep 26, 2005 | 10:11 PM
SilverDc2's Avatar
Default Re: Squeaky Cltuch+GREASY *** TRANNY?!?!?!?!?! (I got sole....)
not true, squeaky clutch means that your clutch springs are worn or loud...
grease all over your tranny... idk
make you car automatic.. i have all the stuff. hah
Old Sep 26, 2005 | 10:14 PM
bonta-kun's Avatar
Default Re: Squeaky Cltuch+GREASY *** TRANNY?!?!?!?!?! (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">not true, squeaky clutch means that your clutch springs are worn or loud...
make you car automatic.. i have all the stuff. hah</TD></TR></TABLE>
Old Sep 26, 2005 | 11:48 PM
IntegraDriver's Avatar
yeah mine squeeks too i think it can be the slave cylinder not too sure if it is where are we supposed to greese it and i heard greesing it alot will mess it up so i dont know
Old Sep 27, 2005 | 12:53 AM
verbal axsassin's Avatar
Default Re: Squeaky Cltuch+GREASY *** TRANNY?!?!?!?!?! (IntegraDriver)
u prolly have a leak. from the hard clutch lines to ur soft lines. are ur clutch fluid low?
Old Sep 27, 2005 | 12:54 AM
Default Re: Squeaky Cltuch+GREASY *** TRANNY?!?!?!?!?! (verbal axsassin)
mine doesnt go low so i dont think its taht
Old Sep 27, 2005 | 09:06 AM
Nataku's Avatar
i clutch peddle squeaks like metal springs not letting go right.
Old Sep 27, 2005 | 01:06 PM
mstolars's Avatar
Default Re: Squeaky Cltuch+GREASY *** TRANNY?!?!?!?!?! (Nataku)
I had a clutch squeek before, but then I pulled off the slave cylinder and put a bunch of grease where the slave cylinder arm contacts the clutch release lever. That helped a lot with the squeeking.
Old Sep 28, 2005 | 04:22 AM
suzawa94's Avatar
Default Re: Squeaky Cltuch+GREASY *** TRANNY?!?!?!?!?! (mstolars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstolars &raquo;</TD></TR><TR><TD CLASS="quote">I had a clutch squeek before, but then I pulled off the slave cylinder and put a bunch of grease where the slave cylinder arm contacts the clutch release lever. That helped a lot with the squeeking.</TD></TR></TABLE>
^^ or you can pull the release fork boot off and spray some lube on it. should definatly help
93sihatchy
Jun 12, 2007 10:35 AM
omega2099
Aug 25, 2004 11:41 AM
Synergy001
Dec 7, 2003 09:42 AM
Heinz57
May 31, 2003 07:14 PM
